Front Lower Strut Mount Adjustable?
My Ride: 2004 525i Alpine White / Tan
So Im in the process of installing my Eibach Pro-Kit and seeing as though I didnt do a little more research before I bought them Im at a bit of a delimna. I do not like the raked look with the front lower than the back and it looks like if I install these (I already installed back, waiting to do fronts) that the front will be .5" lower than the rear. Brainstorming how to correct this rake and make it level I noticed how the front lower strut mounts and it only seems logical to me to just move the strut up measily .5" in the clamp and it would move the ride height of the front up .5" correct? Am I right in assuming that this mount solely is responsible for the vehicle height? Looking to get this clarified before I tackle the front...pics for reference (borrowed from Rizbel's install)
Eibach Pro-Kit Rake:
![](http://img.photobucket.com/albums/v359/baggedLVintegra/DSC_0025.jpg)
Front Lower Strut Mount:
![](http://img.photobucket.com/albums/v359/baggedLVintegra/post-316-1252717625_thumb.jpg)
![](http://img.photobucket.com/albums/v359/baggedLVintegra/post-316-1252718667_thumb.jpg)
This may work BUT you are seriously compromising the suspension and it's components, let alone your safety. I'd strongly recommend you not do this. I wouldn't rely on the bolt to "position" the shock in place. That is not what it is designed to do. All that clamp does is secure it. It needs to be resting on the lower control arm, with this bolt securing it in place.
I got the pro kit springs also so I understand the dilemma you're in, but it ain't all that bad. Besides, I have the V8 so my front is a couple hundred pounds heavier than yours is. Imagine that. good luck
Not going to go through the hassle of uninstalling, selling and buying new coils for the .5".. plus I'm still unsure how this is considered rigged when clearly the strut/ clamp could be locked into any position at the discretion of whoever last worked on the vehicle. Even a BMW tech could mistakenly clamp the strut at different heights as to me (which is why I'm asking for experienced suspension advice) there is no groove or set point of the strut in the clamp
My Ride: '06 550i
'84 Nissan S12 Turbo
I'd say go for it....and see if you can get the height you want. If it doesn't rest on the control arm and there aren't groves or set points, then it sounds like to me it should be safe no matter where it is clamped. Only concern maybe alignment issues....but I don't know for sure
My Ride: '06 550i
![Unsure](https://5series.net/forums/images/smilies/imported/unsure.gif)
If this was the case there would be no need for lowering ranges. If everyone could adjust the ride height by adjusting how far the whole assembly sits then we are all stupid, and the spring manufactuers left out a big secret to scam us. I can't believe it can be that simple. Anyway, GL man...
