Front Grille
My Ride: Alpine White 530i Mtech
Im thinking about painting my front grille myself. I need to know what kind of sand paper should I use and how I should go about this. A little help guys. Thanks
![Post](https://5series.net/forums/images/icons/icon1.gif)
i wouls second that, i want to paint mine too, but want the dull look rather then the chrome i got.
will also be watching this thread carefully over the next few days.
E60BEEMER
E60BEEMER
I saw an e60 yesterday that had the front grill painted and it was chipping off quite badly. For the little I know about painting it is all about prep work ie proper sanding and surface preparation it will need a really good primer for the final top coat to adhere to properly... I would ask a good body shop
Cheers
Cheers
Cheers
Cheers
Originally Posted by Anthony517' post='478040' date='Oct 4 2007, 03:09 PM
Exactly what I hard also, the prep work is key. I was wondering if I should use sand paper (if so what grade) or just use a scuff pad?
I would use a very fine sand paper maybe 180 grit ,then a black primer, then two cots of your final color coat.Even a flat sealer would be a good idea.
Cheers
blackstarr
03-05-2015 04:54 PM
