Fog Lights
hi guys, i'm sorry
but i have to ask this question again. does anyone know how to change the fog light light bulbs on a e60? i just bought a pair of piaa 4700k bulbs but don't know how to change them. i changed all the bulbs myself on my e39 before and it was very simple. in fact, they are quite similar but a little different. i took out the plastic screws but couldn't pull out the brackets (the one that holding the foglights). i called the service dept but they said they can't tell me the instructions due to some liability issues. then i called my salesperson and he said since the car is too new, no one really knows how to change them. they have to take a look at the car and replace them for me...with a $99/hour labor charge
! i think it's ridiculous! i can't wait to put them in, take some pics, and post them here. thank you in advance for your help
![Angry](https://5series.net/forums/images/smilies/imported/angry.gif)
![Talking](https://5series.net/forums/images/icons/icon10.gif)
I had the same question and received no replies. Nevertheless, I have a partial answer. The black grill inserts utilize a snap-in design and can be pulled out of the front fascia. The fog light assemblies are then revealed, at which time the next hurdle is revealed. The assemblies are secured to the fascia from behind, meaning that either the inner fender well has to be loosened/removed or another method of access must be determined. Removing the engine tray does not provide a reasonable angle. Any insight that you or anyone can provide would be appreciated. Cannot wait to replace the fog light bulbs to better match Xenon headlights!
Guest
Posts: n/a
Are you going to replace super white turn signal lights as well?
I got Polarg B1 Hyper White M-7 Bulb 1156 7506 M7 12V 21W but it doesn't fit in my E60.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WDVW
Any idea where can I find right parts?
bmwe60, i'm not going to change the turn signals since it's illegal in my state. i think the best bet for you to make sure the right part is call bmw parts dept. that's what i did cuz e60 is too new for many of the shops outside. after you find out the right size, then there are many places you can get the bulbs, including ebay.
dba1t, i'm still waiting for my buddy's answer. he's been quite busy lately but should be able to give me more instructions w/i this week. in fact, he said it's quite easy. just need to loosen the corner splash shield and remove the bottom protection shield. that you should be able to see the housing.
![Post](https://5series.net/forums/images/icons/icon1.gif)
Alohalc, I installed PIAA Extreme White 4000K bulbs today, replacing the factory Philips bulbs. The procedure for accessing the E60 foglight housings and changing the bulbs is quite simple. The E39 required removal of the housings from the front of the vehicle. Ditto for the E46. The E60 does not require removal of the housings and access to the bulbs is provided from below.
You will need a phillips head screw driver, an 8-millimeter socket, ratchet, and short extension. Start by removing the protective cover beneath the engine. From within the forward section of each inner fender well, remove three 8-millimeter bolts that secure the corner splash shields. The corner splash shields can be removed by depressing plastic tabs which are visible from underneath. Once removed, the wire loom and plug-ins for each foglight are easily accessible.
I have included photos below. Most are self explanatory. Photos taken with the cardboard on the ground in front of the vehicle show a comparison of the factory bulb on the driver's side to the PIAA Extreme White bulb on the passenger side. Photos taken with the cardboard removed are of the completed install, with both PIAA bulbs in place. The improvement is dramatic and the foglights are a much closer match to the Xenon headlights. I did the same on our 2002 M3 Coupe. Your 4700K bulbs will likely be an even closer match.
Good luck. Take care.
![](http://home.fuse.net/tharris/545i/109_0927.jpg)
![](http://home.fuse.net/tharris/545i/109_0929.jpg)
![](http://home.fuse.net/tharris/545i/109_0934.jpg)
![](http://home.fuse.net/tharris/545i/109_0935.jpg)
![](http://home.fuse.net/tharris/545i/109_0939.jpg)
![](http://home.fuse.net/tharris/545i/109_0941.jpg)
![](http://home.fuse.net/tharris/545i/109_0945.jpg)
![](http://home.fuse.net/tharris/545i/109_0948.jpg)
![](http://home.fuse.net/tharris/545i/109_0951.jpg)
![](http://home.fuse.net/tharris/545i/109_0955.jpg)
![](http://home.fuse.net/tharris/545i/109_0956.jpg)
![](http://home.fuse.net/tharris/545i/109_0963.jpg)
![](http://home.fuse.net/tharris/545i/109_0974.jpg)
