First and only! Remodded my moded headlights!
My Ride: 2007 525xi
Nice work there - balls of steel, as always.
I'm surprised no one had taken on the idea of lighting up the fins over the blinkers before. I thought that one would be one that would be screaming "mod me!". Not bad![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
Only thing that's bugging me is the contrast from the Orion's. They're almost a yellow-ish tint. Seems a bit more noticeable with everything blacked out.
Though I suppose that doesn't matter once the rings are on
Yah, I actually went through 5 different designs/set ups, at the end, I have discarded the idea and think if I were to continue, I will be utilizing a switchback system to power the fins instead. As you can see in two pics, I had originally intended to light up each fin by using singular LEDs, unfortunately, due to the length of the top two fins, that didn't work out -- otherwise it actually looked pretty amazing in person.
But yes, the multi LEDs in the fins, that had to go because it looked too Christmas-y to me. Plus with the Orions lit, its brightness is strongly overshadowed by the Orions.
As for opening it back up. It really depends on how you sealed it. I would say mine was quite a handful, and I definitely made new perforations instead of where I plastic soldered because of the silicone, but it can't be avoided. Thankfully, it's my own headlights, so I can deal with it should problem occur. Which I can proudly say no problem at all even after two washes so far
Oh, DK, I thought you did purchase a set of LCI headlights? Isn't that why you bought the LCI eyebrow replacements?
I hope the harness from TheRacerBoss will fix the inner ring going in and out so I don't have to open it up again.
![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
Good job.
![Worthy](https://5series.net/forums/images/smilies/imported/worthy.gif)
My Ride: BMW E60
Model Year: 2016
Though I suppose that doesn't matter once the rings are on![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
I always thought about lighting up the fins like the way you did after I saw M.A.C. E92 M3. But I didn't have LCI headlights. Too bad the single LED didn't work out for the top 2 fins. That would've been nice.
I was going to go with LCI, but settled with the ones I got with the Orions. I still have the LCI eyebrow replacement. That's for later on when I finally jump on the LCI conversion. ![Big Grin](https://5series.net/forums/images/smilies/imported/biggrin.gif)
Good job.![Worthy](https://5series.net/forums/images/smilies/imported/worthy.gif)
Good job.
Humm, so you still have the LCI eyebrow replacement? I actually need a set for a client. I am going to send you a group PM.
My Ride: BMW E60
Model Year: 2016
Thanks for the feedback guys
I think that the average person can probably tell the headlights are custom (even when everything's off), but really only those of us that own the car or are enthusiast will see the quad projector. I am pretty happy that I am the first person to pull this off
![Smile](https://5series.net/forums/images/smilies/imported/smile.png)
![Dance](https://5series.net/forums/images/smilies/imported/dance.gif)
