facelift E60 LED lights installed!
Old May 7, 2007 | 08:16 AM
  #131
bruce_miranda's Avatar
That means my diagram is correct and your word document was wrong again with respect to the bulbs connection. It's amazing how much you can understand with pictures.
Do you have a picture of this loop connection from PIN1 6 to PIN2 4 and PIN2 7?
Also last and most important question. What are the part numbers for the Retrofit Cable that you're BMW electrician used.
Old May 7, 2007 | 08:32 AM
  #132
bmw_wpq31's Avatar
My Ride: MY2005 E60 525i M Sports
Post
bruce, i didn't snap any pictres on the loop connection, but if you want, i'll snap some later...i don't actually know the part no., but i'll check later ok...is the part no stated on the cable? if it is, then i'll check later...
Old May 7, 2007 | 08:44 AM
  #133
Alex.br's Avatar
My Ride: 2007 E60 M5
The E46 plug adapter part number is # 61 12 0 153 650
Old May 7, 2007 | 08:45 AM
  #134
Somewhere in this thread its was mentioned that the E46 retrofit cable was used. However someone said that the E46 retrofit connector had all 7 pins in a single line which is why I'm suspecting that what your BMW garage has used SOMETHING else.
Part numbers are printed on the connectors but they never related to the BMW part they are actually the TYCO/AMP part number. Also in this case you will have part numbers printed on either side of this retrofit connector. It's best to contact your BMW garage and get the part number for the entire piece with all the wires, connectors and housing.
If there are any Grey labels attached to the Retrofit cables then they may provide some clues to the part number used. Lets hope its the E46 retrofit cable but just wanted to make sure. There are enough of p**sed people out there.
Alex.Br : Is another group buy with the lights and the retrofit cables (once we have that part number) possible. I'm sure there are a few of us out there who'd like to move now or missed the last one.
Old May 7, 2007 | 08:56 AM
  #135
bmw_wpq31's Avatar
i'm sorry bruce...the connector cables don't have tags ...i think they've taken it off the cable due to the modifications done to the cable...i'll contact them and get all the parts that they've used later...ok
Old May 7, 2007 | 09:03 AM
  #136
It's OK with me. I'm in no hurry because I didn't buy these lights. Goodness knows why I spent so much time on this project then. Maybe now Alex should get me a good priced set for my effort to the community :-)
However you yourself said you bought the E46 retrofit cables and the garage modified it. Are you saying that you're not sure now. Don't you have a parts invoice that shows the part numbers of the goods you purchased.
Old May 7, 2007 | 09:20 AM
  #137
bmw_wpq31's Avatar
i actually bought the tail lights (due to the plug and play confirmation by xxterxx... ), but the cables (+labour) were bought from the local workshop...
Old May 7, 2007 | 09:21 AM
  #138
Saridi's Avatar
My Ride: 07 Alpine White 525xi
Let me clarify, E46 retrofit cable also do 6pin <-> 7pin conversion, like the one in the pic.........
Old May 7, 2007 | 09:26 AM
  #139
andy545's Avatar
Model Year: 2005
Engine: 545i
Unfortunately I haven't had much time to experiment with my multimeter on the LCI taillights due to double shifts at work..thanks for all the efforts from the other members (bruce, bmw_wpq31, nick etc) - it seems the connections from pre lci > lci has been figured out - it just leaves the exact socket interface to be confirmed and a resistor implementation with the equivalant wattage consumption of a pre lci turn bulb...
Old May 7, 2007 | 09:29 AM
  #140
rjcastr's Avatar
Originally Posted by coolguy' post='412852' date='Apr 12 2007, 01:39 PM
Woah $600 USD!!
i think i like those led.
