exhaust install question
My Ride: 2005 545i- Titanium Gray
Yeah Frank..I am doing a custom quad set up next week actually! I hope to have pics and everything done within the next 2 weeks or so!
Jake
Jake
My Ride: .
Model Year: .
Originally Posted by navin' post='607034' date='Jun 20 2008, 09:00 PM
Went for a longer drive and i love the sound, figured out where the problem is, when the car is in idle a faint vibration comes up from the seats. I can hear the lic plate frame vibrating when i look close.has anyone experienced this? im thinking it has something to do with the way the hangars are holding the muffler...ideas anyone
up side is the wife loves the sound and cannot sense the vibration
![Happy](https://5series.net/forums/images/smilies/imported/happy.gif)
Do you recall how the hangers were installed on the car? That might shed some light on trunk/license plate vibration.
And post some sound clips will ya?
Chennai, India
My Ride: 2005 545i
Originally Posted by mrfva' post='607285' date='Jun 21 2008, 12:01 PM
She claims it's the sound
She might be driving your car more often
And post some sound clips will ya?![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
One hangar is welded onto the side of the muffler and attached to the stock bracket
and the other is welded on to the piping going into the muffler and attached to the stock bracket.
Was thinking pf wrapping something around the hangar rods to see if that stops the vibration,
something like the stuff they sell at kragen to fix muffler leaks.
My Ride: .
Model Year: .
Chennai, India
My Ride: 2005 545i
Can someone else who has a magnaflow muffler installed chime in here and tell me if the brackets on the stock exhaust was removed
and put(welded) onto the magnaflow and the hangar was attached to this bracket on one side and the stock bracket on the chassis on the other?
Or was the hangar welded directly onto the muffler and attached the stock bracket on the chassis ?
Help please
, this vibration is driving me mad
Help please
![Crying](https://5series.net/forums/images/smilies/imported/crying.gif)
Chennai, India
My Ride: 2005 545i
Does anyone know what that is ?
It looks like a vibration damper although i also found a very thin rubber tube hanging above the muffler coming from inside the rear bumper
![](https://i299.photobucket.com/albums/mm315/navinarayanan/CIMG5136-1.jpg)
But i cannot seem to find that part listed on real oem
![](https://i299.photobucket.com/albums/mm315/navinarayanan/189.png)
help please
help please
Chennai, India
My Ride: 2005 545i
Could part 11 be the electronic controller for the vale connected to part 12 which is the hose I'm seeing coming from inside the bumper?
In which case that is the valve to push into the secondary muffler under load and not a vibration damper.
Sorry for asking questions and trying to answer them at the same time
![Wacko](https://5series.net/forums/images/smilies/imported/wacko.gif)
help please
help please
Regarding your vibration, magnaflow do tend to vibrate more than others because of the low frequency production, but it should not cause vibration as you described. Additionally, make sure the muffler guy did not attach additional hangers onto the chassis of the car without the rubber damper. BTW, it's normal to have hangers welded on to mufflers.
On the other hand, if there is not enough hangers for the new muffler, the vibration will concentrate on the single hanger, and that vibration may lead directly to under your seat.
When I had the dual magnaflow 4" rounds, I had a slight vibration at the steering wheel on idle. If you install additional hangers, make sure to use the OE ones. Some muffler shops tend to use the cheaper flat rubbers that don't isolate vibration very well.
My guess is that if he used additional hangers, it's got cheap rubber dampers. The other case is that he may need an additional hanger.
Does your new muffler/tip vibrate on idle? Have someone (wife) look at the tips from a distance when you reve the engine. If it moves, take it back to the muffler guy.
Chennai, India
My Ride: 2005 545i
Originally Posted by Bimmer32' post='608102' date='Jun 22 2008, 10:30 PM
The part you are looking at is called the butterfly valve. Under heavy load, the valve is opened to allow exhaust to exit both stock mufflers.
So you might be right that the dampers on these are cheap and not actually damping well.
I will take the car to a muffler guy and put the stock dampers on the new hangers.
Thank you for the advice, will let you know how it turns out.
