eoro stickers
if they are from or similar to the ones member akalius sells...there is a DIY in his FS thread..
http://forums.e60.net/index.php?showtopic=59898&hl=
here you go, this is from member Akalius.
***For best results keep the stickers out of the heat prior to doing the application. As the heat will make the clear masking peel off of the euro sets and will make your install harder.***
Wet Application: For best results, keep stickers out of the heat prior to application.
1. Clean the area with a solution of 1/2 water, 1/2 alcohol.
2. Make sure the area is completely dry and free of debris.
3. Wet the surface area where the sticker is to be applied
4. Peel off the white backing sheet and wet the back of the sticker where it is sticky. Make sure it is very damp.
5. Make sure you do NOT peel off the CLEAR masking layer.
6. Carefully, position the sticker starting from the outer corner of your headlight, holding the whole sticker over where you would like for it to be applied, and do not apply the whole sticker all at once. ( The top black edge of the overlay should go exactly over the black outline of the headlight. If this is done correctly there will be no orange visible.)
7. Once the outer corner is on and aligned, use the edge of a credit card to apply the sticker, starting from the outer corner of the headlight working your way in using smooth swiping motion. (There shouldn't be any bubbles if the sticker is applied evenly. original.gif)
8. Once you have applied the sticker, if there are still bubbles, you can easily swipe them out using the edge of a credit card or simply use your fingertips to push them out.
9. Let the stickers settle, with the clear masking layer still on, for 2 hours.
10. Repeat on other side.
11. Once your stickers have settled, carefully peel off the clear masking layer from both headlights.
My Ride: Original E60 Spec:
530i - Silver Grey Out, Black Dakota Leather In, Navigation Pro, Voice Command, HiFi Audio, Sports Package, Premium Package, Cold Weather Package w/ Heated Seats, Style# 123 Alloy Track Wheels, Auto AC, Power Front Seats, Active Turn Xennon Headlights,
Mods:
OEM M-Tech Front Bumper, OEM M Side Skirts, OEM M5 Rear Bumper, M5 Trunk Lid Finisher, M5 Style Mirrors, Custom Hamann Style Splitter, Custom Hartge Style Diffuser, RD Sport Boot Spoiler, LCI Taillights, Bruce Miranda's V4 LCI Retro Cables, 6000K Xenon light Bulbs, Xenon White LED License Plate Lights, 8000K HID 9006 Fog Lights, Akalius� Front Headlight Euro Overlays, Matte Black Kidney Grilles, E60.Net Clings, Debadged, Llumar Tinting "Micro Edged, 15% Rear 35% Sides,
Engine Mods:
Custom Magnaflow Quad Exhaust w/ Eisenmann Stamped 3� Tips, RPI Scoop (Red)
Added Electronics:
V1 Equipped (Hardwired), OEM Alpine CD Changer Retrofit,
Shoes:
SOLD-20" Staggered Vertini Hennesey Rims, Falcon 452's Tires-SOLD
New Shoes:
19" VMR 710 Hyper Silver, General Exclaim UHP 245/35/19 Front-275/30/19 Rear, Gloss Silver Caliper Paint Job DIY
^_____________
Retired
______________
Took Delivery 10/26/2009: LOADED! E60 M5 Silverstone II/Black, Active Seats, Comfort Ventilated/Heated Seats, HUD, Brushed Aluminum Trim,
THanks Radz, but I added more details since then. Step #3.
3. Wet the surface area where the sticker is to be applied with ONLY WATER NO ALCOHOL.
1. Clean the area with a solution of 1/2 water, 1/2 RUBBING alcohol.
Originally Posted by Howitzer' post='789415' date='Feb 10 2009, 12:54 PM
Anyone else get the euro stickers only to remove them a few months or weeks later because you realized that you put stickers on your BMW?
![Badbad](https://5series.net/forums/images/smilies/imported/badbad.gif)
Originally Posted by Howitzer' post='789442' date='Feb 10 2009, 01:19 PM
I dunno, I liked it at first, but then after a time I ripped them clean off in a fit of rage realizing I had cheap stickers on my Bimmer.
Originally Posted by radzM550i' post='789450' date='Feb 10 2009, 01:24 PM
get the eurospec headlights, they look very nice!
If I was to do that I'd just get LCI front lights. But those are like $2000+
