ECU, airbag with gateway module, Part # 65776975686
2 Attachment(s)
HI,
I have a BMW 04/2005 E60 530i and have had the following message displaying for nearly a couple years: Restraint system faulty! Function of airbags, belt tensioners and belt force limiters faulty. etc I recently had the car serviced and my guy said faulty part is: 65776946388 - ECU, airbag with gateway module Alternative part #'s seem to be: part number 65776975686 alternate stock code 65776946388, 65776943089, 65776957029, 65776960383, 5776962703 Been conversing with an eBay seller who provides 2 month warranty and guarantees part is without error and said it's compatible with my E60. https://5series.net/forums/attachmen...1&d=1433653748 eBay part I believe the part is located behind the glove box but have been unable to remove to check the part # to determine if it's located there. https://5series.net/forums/attachmen...1&d=1433653748 My glovebox It appears to have a plastic clip either side but I can't remove/slide out the existing box. Please, any suggestions how I can remove it. Cheerz :) :D ;) |
Looks like you bend those clips outward and pull the box out.
Originally Posted by twh
(Post 1564255)
Thanks for replying, yes, it was a very tight fit, after placing thin cardboard strips to keep clips out, after a bit of wiggling, it started to slide out. Finished up being the same part # as the guy is listing on eBay, I just need to contact my service guy to see if my part is the faulty one. Cheerz :) :D ;) |
Originally Posted by daMANiack
(Post 1564269)
Hi,
Thanks for replying, yes, it was a very tight fit, after placing thin cardboard strips to keep clips out, after a bit of wiggling, it started to slide out. Finished up being the same part # as the guy is listing on eBay, I just need to contact my service guy to see if my part is the faulty one. Cheerz :) :D ;) Did you end up replacing the part? Did you need to code it or it was plug and play? From what I have research from the internet is: I can be replace modules with used ones, but they need to be reprogram with my VIN. Has anyone use WinKfp to re-program modules with your car VIN? |
Originally Posted by tivinps
(Post 1580119)
Hi
Originally Posted by sparky
(Post 1580132)
It's not a plug and play procedure. As far as i remember when i replaced my gateway module with a used one, but with a newer part number than mine, i had first reprogrammed it using winkfp, then code it with ncsexpert and finally reset airbag satelites using ISTA/D to make it work and get rid off that error each time i turned the car on.
My indy shop only needs that I I edit the VIN and he can re-sync with all car modules. |
(Post 1580133)
Do you remember the process in WinKfp to edit the VIN?
(Post 1580134)
Unfortunately it was reprogrammed by a workshop for me, really sorry buddy i don't know any of the procedure to help you out with it.
