e90 wheels
Originally Posted by gpinkwater' post='1094246' date='Jan 20 2010, 10:17 PM
Will e90 wheels fit on an e60 ?
My Ride: 2006 550i pretty stock so far
Originally Posted by acuteperformance' post='1094256' date='Jan 20 2010, 03:23 PM
no they won't since the offset is too high. the e90 m3 would though.
Originally Posted by gpinkwater' post='1094261' date='Jan 20 2010, 10:27 PM
So ifg i am understanding correctly, if they were installed they would stick out of the wheel well too much or too little?
edit: ...and they would probably rub on the inner side.
too little. high offset means the wheels are too in and low offset means they come out more.
Originally Posted by acuteperformance' post='1094272' date='Jan 20 2010, 03:39 PM
sure they might work (make sure the wheel clears your brake caliper) but you'd need a pretty thick spacer 1cm-1.5cm and then need to purchase longer bolts to secure your wheels. i wouldn't do it personally nor would i recommend anyone else.
Originally Posted by gpinkwater' post='1094289' date='Jan 20 2010, 12:55 PM
Would spacers make them work? Do you give up performace or handeling with big spacers?
Originally Posted by acuteperformance' post='1094293' date='Jan 20 2010, 10:58 PM
