E61 Sound system modification CCC-->CIC
My Ride: is black
Model Year: 535
Small progress...
More wires came
![](http://i1089.photobucket.com/albums/i346/wooboodoo/Touring/image_zps79242b5f.jpg)
Connector and pins from tischer BMW
![](http://i1089.photobucket.com/albums/i346/wooboodoo/Touring/image_zps7db3929e.jpg)
Finally I could put all wires together, I decided to run in my harness also cable for MS-8 screen
![](http://i1089.photobucket.com/albums/i346/wooboodoo/Touring/image_zpsc21cb0b3.jpg)
Little bit cloth (friction) tape to hold the wires together nice and tight and I have "almost" harness![Wink](https://5series.net/forums/images/smilies/imported/wink.gif)
That two longer pieces are for MS-8 screen and front center speaker.
![](http://i1089.photobucket.com/albums/i346/wooboodoo/Touring/image_zps98c7f638.jpg)
Woofers wiring plus remote (white/violet), still need two thick wires to power up MS-8
![](http://i1089.photobucket.com/albums/i346/wooboodoo/Touring/image_zpsd2e89443.jpg)
Center speaker for now OEM logic 7 I can always replace it...
![](http://i1089.photobucket.com/albums/i346/wooboodoo/Touring/image_zps394d9a83.jpg)
![](http://i1089.photobucket.com/albums/i346/wooboodoo/Touring/image_zps3a3927fd.jpg)
Now waiting for crimping tool and other toys to finish my harness![Thumbsup](https://5series.net/forums/images/smilies/imported/thumbsup.gif)
tbc...
More wires came
tbc...
OLE!!
U are MOVING way faster then me for the upgrade ![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
maybe i should ask u to help me do the retrofit![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
what do u think?
what do u think?
My Ride: is black
Model Year: 535
So you are upgrading to logic 7 correct? With OEM amplifier as long as I remember?
If so you gonna need 2 extra speakers for rear door and center speaker. Do you want to replace all current speakers for logic 7 speakers?
Of course I can help you out .
i will upgrade to L7 SYSTEM
i have (purchase) a L7 AMP
i have(PURCHASE) all 11 speakers BSW (7 mid range and 4 tweeters) and the L7 OEM SUBS...
i PURCHASE NBT with itouch idrive and all cables., the pins and connectors and emulators to make it work( coded to my cars specs..)
i also have all the pins ..connectors..to retrofit the L7 amp and speakers...
all i am waiting for is a set of 2 "Y" MOST FO CABLES..for PNP to the L7 AMP AND TH TV emulator for the NBT,,,,AND i can get regular speakers wires..but i prefer..OEM( WICH u come in play.![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
so...if u willing to help( like the home depot add: if u can do it...i can help)..
we can set up a day( sunday will be great) and i can come down to u...DONATE..SOME $$,,,and take a lot of pictures of the project..to HELP others...
let me know
STELI
let me know
STELI
My Ride: is black
Model Year: 535
NBT ! Damn lucky you ![Wink](https://5series.net/forums/images/smilies/imported/wink.gif)
I was thinking about it but finally got cic...
We need some plan how to do your harness, my are much simpler cause I gonna use OEM wires from center console to the speakers and from the trunk to the subs...
For your car we need to run totally new harness from the trunk to the center speaker.
Would be great to get some idea about the lengths of wires and find best way to run them.
I gonna run my harness on the left side under the carpet in wire channel, 5 series has one wire channel or 2? I don't even know that lol
pm me with your phone number..![Smile](https://5series.net/forums/images/smilies/imported/smile.gif)
it will be so easy when there will be two of us..
if we run into a problem..at list we dont freak out...2 brains its better then one /
incoherent
04-15-2015 04:48 PM
