E61 535d Paddle shift mod.
Old 11-23-2014, 12:59 AM
Mission1979's Avatar
My Ride: BMW 535d Touring
Default E61 535d Paddle shift mod.
Hi everyone,
Took my airbag off today today to swap the left hand paddle to do down on pulling towards me and up on pushing away. Straightforward according to threads on other forums.
Simple swap wires going in to pins one and three in a three pin plug, only thing is, I've got a four wire plug, different colours either side too, threads suggest they're all black.
Help!..
Old 11-23-2014, 01:07 AM
sanjsanj's Avatar
My Ride: E60 530d
post some pics - do you not see any numbers on the connector?
Old 11-23-2014, 04:09 AM
1st picture is left hand switch, steering wheel is turned over to remove air bag.
2nd picture is right hand side.
The plug I've removed has numbers 1-4 on, tried to get multimeter on to check connections but it was too awkward.
Thanks
Attached Thumbnails E61 535d Paddle shift mod.-imag0954.jpg   E61 535d Paddle shift mod.-imag0953.jpg
Old 11-23-2014, 11:06 AM
sanjsanj's Avatar
My Ride: E60 530d
you're better off looking on WDS, it has the colour codes for each wire
WDS BMW Wiring Diagram System - Model Selection
Brown is most likely ground though, so that should get you started...
Old 11-23-2014, 12:39 PM
stel_i79's Avatar
My Ride: 530i N52
Engine: n52
check xxx.motivemods.com.....chnage xxx with www
good luck
i got mine from there.....PNP....
Old 11-24-2014, 10:16 PM
Thanks for the link, tried three computers so far and I get java issues and I've tried updating it and it always checks version and it's out of date.
Got a diagram up before it updated but I couldn't zoom into read it, after it updated can't even do that.
Could anyone do me a screen dump of the paddle shift for 2008 lci?
Old 11-25-2014, 01:56 AM
sanjsanj's Avatar
My Ride: E60 530d
where in the menu do I need to click on to get the diagram up?
Old 11-25-2014, 10:33 AM
Not sure now, there was a section with paddle shift, under steering wheel I think. Can't even see the hierarchy list so I can pick from there.
Thanks
Old 11-25-2014, 12:14 PM
funglenn's Avatar
My Ride: 530ix
Model Year: 2020
not to Hijack, but can I add paddles to a non paddle steering wheel? mine is heated and I do not want to loose that feature
Old 11-29-2014, 05:31 AM
Got the wiring diagram to work now but there is so many places to look, I cannot find the reference for the two four pin paddle shift connectors.
Found the ones for the M5, they are three pin connectors and make sense.
Help?!?
Quick Reply: E61 535d Paddle shift mod.
