E60 Lcm problem after retrofitting Headlights
Old Nov 12, 2023 | 01:26 PM
Dapr's Avatar
My Ride: 520i e60 2005
Default E60 Lcm problem after retrofitting Headlights
So basically the headlights are lci and tail lights pre lci I have the lcm2 module when I plug it in everything works 10 seconds pass the both the brake lights turn off and don’t work. If I swap it with the old lcm then they work normally.
My question is whether it’s a wiring issue or a coding issue?
Old Nov 13, 2023 | 09:41 AM
neilv's Avatar
My Ride: E61 530xi 6MT
Engine: N52
Have you coded the LM2 module to your car? alternatively did you get the right LM2 version? AHL or standard xenon/halogen?
Old Nov 20, 2023 | 05:43 AM
Dapr's Avatar
]Have you coded the LM2 module to your car? alternatively did you get the right LM2 version? AHL or standard xenon/halogen?
i have one lm2 that is coded to the car but I bought another one to see if it will fix it but with the new used lm2 almost all the lights turned off after 10 seconds. The other lm2 is the correct one and the only problem is that the rear brake lights short circuit. It’s a standard xenon and the same with the other one I bought.
i have tried removing it with tool32 they come on but turn off again after 10-20 seconds.
Old Jan 14, 2024 | 02:13 AM
piehole1983's Avatar
My Ride: 2003 E60 530i SE Auto, 2007 535d M Sport Auto
Model Year: 09/2003, 01/2007
Engine: M54B30, M57D30T1
I did this when I was retrofitting adaptive xenon’s to my halogen car. I’m almost sure I had to re-pin the plug at the LM for the brake lights to work properly as well as some other stuff. I still have the rough notes lying about somewhere, I’ll try to find them and let you know whats written down.
Old Jan 24, 2024 | 06:20 AM
bwsujags's Avatar
My Ride: 2009 BMW 528i xdrive
Model Year: 2009 528i Xdrive
Engine: N52 Engine
Default Retrofit of Headlamp Assemblies
Good Morning:
I have a 2009 BMW 528i X-Drive. I want to retrofit it with headlamp assemblies from an 04-07 5 series. Is it possible? If so, how do I go about doing it. What will be the wiring issues? Your assistance is greatly appreciated. Thanks!!!
Old Jun 12, 2025 | 03:26 AM
Zuxxas's Avatar
Default E60 pre lci to lci
Guys,i got the same problem i bought lci bixenons and i made the retrofit but only headlights,my tail lights are still prelci,so the tails lights dont work with lm2 module but with my lm module they work but the angel eyes dont work,what should i do to fix it?
Ork_Sina
Oct 7, 2023 09:52 AM
Gad1nski
Nov 14, 2021 10:08 PM
rizwan1377
Apr 5, 2015 05:22 PM
Jc-ay22
Mar 24, 2015 06:09 PM
Nickolaus
E60 M5 Discussion
Jul 25, 2010 12:36 PM
