E60 LCI quad-bixenon retrofit
My Ride: 2008 BMW 528i
Engine: N52K
Hello,
I am trying to install quad bixenon setup with led angel eye rings. My car has halogen projector with halogen high beams. i have installed hid and enabled xenon using NCS expert. but for some reason i cannot use high beams. the option to use bi xenons for high beams is disabled and i can use halogen high beams as flash to pass. my lenses were pretty dull and i am getting 2 new zkw lenses and 3inch bi xenon projector housing to add as a quad bixenon.
Now how do i go about wiring the bi xenon flap to the LCM ? its a 2008 LCI 528i. I can pull some more info if needed. I do not have any dynamic headlight options. its just the base model. I need some help with the bi xenon wiring. which wire to tap into or where should i route the new cables to and how to change the pin out on the existing wiring harnes. I read some posts but they all had dynamic headlights from the factory and the pinouts are different on those harness. any way to enable the rear fog light without the EU LCM ? FYI I am in US.
Thank you
Thank you
