1 Attachment(s)
How to remove the small pull handle on pre-LCI interior (the small handle under the door wood trim below)?
The panel is already pried (just need to lift it off the door and disconnect cables) Unfortunately TIS is missing this info, should be here: http://tis.spaghetticoder.org/s/view.pl?1/09/13/83 |
I am not 100% sure cause I have LCI, but I believe I saw it somewhere similar to how it is with LCI that you would still need to remove the interior door panel.
Believe this one might help: http://tis.spaghetticoder.org/s/view.pl?1/08/86/87 |
Yeah that's what I've used for the door panel. Guess I must fully remove it to get at the handle. Thanks.
