E60 amp installation
Old 06-22-2012, 10:12 AM
sd_dracula's Avatar
Looking for a place to install an amp in the trunk and just wondering if the location below is safe.
A few things, no I can't install it in the left corner of the trunk (as per Bruce's DIY), it's too wide, the spare wheel is in the trunk so can't put it in there
and I don't want to drill the rear seats.
Was thinking to just add something like a bit of plywood to the area below (its Styrofoam) and place the amp on that.
Should be good since I don't carry anything with the car.
Is there a reason not to put it there?
Attached Thumbnails E60 amp installation-img_0944-copy.jpg   E60 amp installation-img_0942-copy.jpg
Old 06-22-2012, 04:58 PM
rest0r's Avatar
My Ride: 2008 535i Alpine White w/ Gray Interior; Premium, Sports, Cold Weather; Comfort Access, NAV, iPod Adapter, Sat Radio Upgrades: ★ OEM 166 (245/35F : 275/30R) ★ Motorcepts HID AEs & Fogs ★ License Plate LEDs ★ 35% Tints ★ Wish List: MTech Kit : Matte Black Kidney Grilles : R1 Concepts / Hawk Brake Kit : Blacked-out Orion Headlights
Optimal location is in the left corner since there is a vent there, but if it doesn't fit not much you can do there. The location you marked-up in red is pretty much the only option unless you attach it somehow to the underside of the rear deck.
If you place it on plywood in that location, just make sure to secure the plywood somehow. You don't want the amp to shift and leave the bare power wire in the trunk. Good luck.
Old 06-23-2012, 01:57 AM
sd_dracula's Avatar
I was thinking about underneath the rear shelf but the manual and also the audio installer suggested never to that since the amp will die in a few months due to improper ventilation, being upside down.
Old 06-23-2012, 06:48 AM
nelson29's Avatar
My Ride: 2005 530i Silver Gray/ Gray Leather. SP,PP
How about rear deck?
Old 06-26-2012, 12:55 PM
wbpt12's Avatar
My Ride: 535i sport
Here's my rear deck install.. I love it, stays out of the way and cool.E60 amp installation-imag0051-1380209316.jpg
Old 06-26-2012, 01:21 PM
tonyb635's Avatar
Are you also installing a sub? I did and mounted the amp on the sub box. I also had heard that the amp needed ventilation but I just didn't want to drill and mount on the underside of the deck. I did on an old M3 I had and for several years no problems at all.
Old 06-27-2012, 10:04 AM
subterFUSE's Avatar
That's what we did for my car. Metal frame attached to underside of rear deck, and then all componets mounted to the rack. Minimal screws going into the car frame, and max retention of truck space. The only thing to keep in mind is that if your amp is very high-current, then you'll want an amp with an internal fan to aid in cooling. However, I am running my Audison LRx4.1k amp under the deck with no problems.
Old 06-27-2012, 01:36 PM
sd_dracula's Avatar
Putting the amp upside is the biggest no-no if it only has passive cooling, that's according to the Alpine manual and any audio installers I've asked. Being a 5 channel amp that might be the case, Alpine MRX-v70, anyone has any experience with that one?
It will work not for more than a few months if the car gets used a lot, apparently.
For how long? My only concern is lifespan since getting good amps in Europe is a bit of a gamble so I'd need to get one from the US and I don't want to go through the hassle of sending it back in 3 months for example.
Old 06-27-2012, 03:02 PM
subterFUSE's Avatar
It has been 3 years, with no issues. I did ask about mounting upside down, but my installer said the Audison has a cooling fan.
Old 06-28-2012, 05:33 AM
sd_dracula's Avatar
Fair enough. That explains it then
Quick Reply: E60 amp installation
