E60 530i CIC, Combox & Multimedia controller upgrade
My Ride: 2004 E60 530i (EUR) RL, Titansilber Metallic,CIC & COMBOX retrofit with AUX/USB in centre console, sport button retrofit
Engine: M54
E60 530i CIC & Combox upgrade mic problem
Hi all, wondering if anyone could help me with a mic problem. I recently purchased CIC, combox & multimedia controller overseas precise to my VIN, everything works great, the only problem I have is my mic connection. The wires connected to the mic are white/green & white/red, when I connect the same colours including the shield to the combox I have no mic on my calls. I’ve pulled out the glove box to see if I had that plug that needs the wires switched and no plug. I’ve traced the wires to the cluster block in the head unit but don’t know where they go from there. Next to the mic is another plug tucked away with brown/white & white wires, I connected these at the combox and mic works on calls. The problem is now I can’t use the voice recognition button. Does anyone have a solution?
I know I should have followed the pin out diagram from the start but I made a huge mistake when moving pins from 54 to 26 pin plug and confused the whole project and then had to follow correct pin outs using wire colour codes
Maddog-99
11-20-2012 04:38 PM
Maddog-99
08-10-2012 07:29 PM
