E60 520d 2008 Bluetooth Coding with NCS Expert
My Ride: 520d
Hello,
I have a 2008 E60 520d which does have any bluetooth installed/enabled. It only haves AUX.
I have watched some videos and did search but didnt get it correctly.
Is it possible to code/enable bluetooth to my car? And how can i then code it?
My Ride: 520d
I have attached how i did it:
first i found out which wire was which(from the bluetooth adapter) channel using the picture below.
Yellow: Right
White: Left
Red: Ground
Next i checked which was which from the Rear AUX port of the BMW
Black: Left
Yellow: Right
Thick: Ground
i then removed the cables from the aux port and soldered them to eachother (adapter to AUX port obv.) (maybe not as beautifully done but it works)
then just do the same with power. then put the adapter in the rear console and close everything off.
works beautifully!
Yellow: Right
White: Left
Red: Ground
Black: Left
Yellow: Right
Thick: Ground
works beautifully!
