E60 with 245/35/20 and 285/30/20 Size from M5!! Is this fit fo
![Post](https://5series.net/forums/images/icons/icon1.gif)
hi, soory my english is not perfect..... :'(
I have E60 with M-Aerokit and Eibach Springs -30mm. I have bought Schnitzer Typ V 9x20 and 10x20 rims.
The normaly tyre for this size: 245/30/20 and 285/25/20 :thumbsdown:
I might 245/35/20 and 285/30/20 (size from M5)
Does this go? Does this fit in front?
![Blink](https://5series.net/forums/images/smilies/imported/blink.gif)
My Ride: 535d Sport, carbon black, media pack, visibility pack, grey leather, heated seats, sun protection glass, voice control, Eibach ProKit, 19" 166 style wheels, e-maps ECU remap to 325hp and 640NM, top speed limiter removed
245/35/20 and 275/30/20 should fit, but will kick the speedo out, which in turn could land you in trouble with the TUV Eintragung. These sizes are pretty commonly used on US 20" conversions. The ACS Gutachten should tell you which tyres to use, otherwise it might have to be single type approval. (Einzelabnahme)
Instead of 245/30/20 and 285/25/20, if you want a little more meat on the tyres you could go 255/30/20 and 295/25/20
Hi,
the circumference for 245/35/19 is: 2000mm (E60) diameter:655mm
for 255/30/20 is 2019mm (E60) diameter:668mm
for 255/40/19 is 2095mm (M5)diameter:695mm
my wish 245/35/20 is 2075mm diameter 680mm
