E60 2006 523i HID Problem
Hi.
I had my low beam bulbs replaced by Philips Xenon bulbs just a 5 days ago.
Everythings ok. light output, colors, no light error on the PDC. Problem is, if the key is turned on (engine not started yet), and the light switch is in the "off" position,
the bulb just flickers for around 5secs before dying out. Its like a strobe light from a police car.
Im not sure if its normal or not, but the tech guy that had it installed says it is.
Any of you guys had this experience ?
Any help or comment will be greatly appreciated.
My Ride: 2005 545i E60 Orient Blau Metallic
Premium, NAV, Winter Package, Heads Up Display, Logic 7 Audio, AngeliBright Upgrade [White], M5 Body Kit, M Embroidered Seats
What you are experiencing is called "strobing." Happens frequently with third-party vendor bulbs in the AE or low/high beam position. On startup the ECU on our cars checks to make sure that all voltage responses are correct for electric components by firing low voltage signals. The OEM bulbs supress this - probably through inbuilt proprietary technology. The third party bulbs dont and you see flickering - like disco lights - as the ECU checks to make sure nothings warped, fused, etc....
Bottom line - it IS normal and you shouldnt worry.....
S
S
S
S
Thanks for the informative explanation. appreciate it.
Originally Posted by uyhok' post='773443' date='Jan 21 2009, 11:02 AM
Are there any workaround to stop it besides replacing with oems ?
I think it looks kinda cool personally and I always get positive comments about it when the car goes in for svc.....
S
Originally Posted by subarashi' post='773465' date='Jan 22 2009, 12:25 AM
No..not really. Its the way the ECU functions at bootup. I don't know if resistors or devices can be placed to stop them - will probably cause more problems for you down the road and not worth the headache. You will notice tho - that it becomes less frequent [won't happen at every startup] as time wears on..... Or maybe that's just me..
S
S
Anyway, thanks for your help.
Regards
kane1111
04-10-2015 04:40 PM
