E46 M3 18x8.5 Rims
Hold the phone, I am using my ex M3 BBS LM wheels and they work great. The rears do bolt right on, the front does need spacers and longer bolts (got mine from Turner Motorsport) but I used 20MM spacers with my BBS wheels.
The front wheels will NOT stick out, the spacer just makes up for the incorrect offset. It?s like adding material to the rim (make sense)
For tires I had OEM standard staggered size 18" NON run flat tires installed. Works great. I think it would work fine and look cool.
I wouldn't use the fronts all around. The wider M3 rear will also fit and the staggered set up looks aweseome.
Those arent factory offsets though thats how you're bbs's work, I ran ones just like yours too!
Vman33
03-14-2022 04:43 AM
bestofthebest
03-28-2016 02:47 PM
