Dopey Mechanic Removed Brake Sensor "Receiver"
My Ride: E61 530Xi MT
I've been struggling for two days to replace my front brake pad wear sensor. The first day I struggled because I had confused the ABS sensor with the brake sensor. The second day I figured out that the receiver that I'm supposed to plug the sensor into has been completely removed from my car by a dopey local mechanic.
When I open up the box that should have both the blue ABS connector and the white brake wear connector, only the blue ABS connector is present. The white "receiver" collar is completely missing from the box, so I've got nothing to plug the new wear sensor into.
I removed the wheel well splash guards and started peeking around to see if the cable had been stuffed up inside for some stupid reason, but it appears to have been completely removed from my car.
Can anyone tell me: 1) What is the part number for the "receiver" side of the front brake wear sensor, and 2) Where is it supposed to run and what does the other end of the harness plug into?
EDIT: I'm such an idiot. I was looking on the wrong side of the car!!
Engine: N54
Are you sure you are not looking on the wrong side of the car? ... Go look at the other side
Engine: N54
If it turns out to be on the other side... welcome to the "idiot" things we do!
https://bmw.spoolstreet.com/threads/...an-idiot.3522/
I definitely look like an idiot on this one. I already hassled my mechanic over "his mistake," but today at lunch took a look behind the front driver-side wheel... There are two cables there!
I guess for my year E61, the front wear sensor is on the (US) driver's side and the rear wear sensor is on the passenger side. I swear somebody told me the front sensor was also on the passenger side...
Excited to go home and get this sucker installed so my brake light & on-screen warning will finally shut off after all these months. After that, I only have half a dozen more repairs to go...
Engine: N54
Glad you got it sorted out!
Be sure to check out spoolstreet too. A lot more support over there these days
My Ride: 5 series
pjk0159
04-07-2013 05:24 AM
Almighty JungleBoy
Bluetooth & Cell Phone Forum
01-16-2006 08:27 AM
tedmundson
10-28-2004 12:40 PM
