Do all Brake Disk cross drilled point forward?
My Ride: Mini Cooper
Originally Posted by ImSort0fABigDeal' post='648993' date='Aug 18 2008, 09:02 PM
I hope mine point correctly
If they are Curved vane then the holes have to point the same way as the Curved vane.
My Ride: 08 550 Carbon Sport Almost everything factory, but no sound upgrades.
If not straight, then there should be a different disc for the left side and right side if you want them to aim the same way. I think pingu's post hinted at this.
I wonder if it really makes a difference? Each hole is independent.
My Ride: G30 M550i
Model Year: 2018
Originally Posted by Brembo
Orienting the disc in the manner creates a centrifugal pump. The rotation of the disc causes air to be pumped from the center of the disc, through the vanes, and out through the outside diameter of the disc.
QUOTE (sixcard @ Aug 18 2008, 11:21 AM)
According to the quote I posted from Brembo, it can make a difference...
QUOTE (Brembo)
That does make sense.
Perhaps if the pattern is straight the cooling affect is limited to narrow bands radiating outward.
The staggered pattern of the holes may spread out the cooling affect over a more uniform pattern of the disc. If this jibes, does the forward or backward scheme make a difference?
I?m no brake expert, just considering how/why this works.
QUOTE (Brembo)
[/quote]
+1 I like to know too if any of you guys are Brake disk expert
[/quote]
TexaZ3
05-06-2015 09:54 AM
kane1111
04-10-2015 04:40 PM
