disabling the rear bulb errors
My Ride: coilvers retrofits
Model Year: 2001 and 2011
i just got some LCI tails and came with some adapters (not bruce's) and they work fine, with ricky effect, but im getting rear brake bulbs errors for the rear, and ive been searching for what to code to disable them and cant seem to find it. any help?
i plan to build something soon or upgrade to lm2, but in the meantime i just want to get rid of these errors for the time being. any help highly appreciated!
https://www.facebook.com/Tripl3OCoding
he did it on my car but i have the lci retrofit with lm2( and i have simons hard wire break effect)
give him a buzz
give him a buzz
You can read this: Bulb Cold/Warm Check
In LMA Module
COLD MONITORING PARAMETERS:
aktiv => nicht_aktiv
KALTUEBERWACHUNG_BL_L (Brake Light Left)
KALTUEBERWACHUNG_BL_M_1 (Brake Light Middle/Center)
KALTUEBERWACHUNG_BL_R (Brake Light Right)
WARM MONITORING PARAMETERS:
WARMUEBERWACHUNG_BL_L (Brake Light Left)
WARMUEBERWACHUNG_BL_M_1 (Brake Light Middle/Center)
WARMUEBERWACHUNG_BL_R (Brake Light Right)
ERROR MESSAGES CHECK CONTROL PARAMETERS:
FEHLERMELDUNG_CC_BL_L (Brake Light Left)
FEHLERMELDUNG_CC_BL_M_1 (Brake Light Middle/Center)
FEHLERMELDUNG_CC_BL_R (Brake Light Right)
I hope it will help
In LMA Module
I hope it will help
i changed all these to nicht_aktiv and did the trick. thanks!
;Check Control parameters
FEHLERMELDUNG_CC_BLK_H_L turn signal rear left
FEHLERMELDUNG_CC_BLK_H_R turn signal rear right
FEHLERMELDUNG_CC_BL_L brake light left
FEHLERMELDUNG_CC_BL_R brake light right
FEHLERMELDUNG_CC_RFS_L reverse light left
FEHLERMELDUNG_CC_RFS_R reverse light right
FEHLERMELD_CC_RL_BL_1_L tail light 1 left
FEHLERMELD_CC_RL_BL_1_R tail light 1 right
FEHLERMELD_CC_RL_BL_2_L tail light 2 left
FEHLERMELD_CC_RL_BL_2_R tail light 2 right
;Cold Monitoring parameters
KALTUEBERWACHUNG_BL_L brake light left
KALTUEBERWACHUNG_BL_R brake light right
KALTUEBERWACHUNG_RFS_L reverse light left
KALTUEBERWACHUNG_RFS_R reverse light right
KALTUEBERW_RL_BL_1_L tail light 1 left
KALTUEBERW_RL_BL_1_R tail light 1 right
KALTUEBERW_RL_BL_2_L tail light 2 left
KALTUEBERW_RL_BL_2_R tail light 2 right
;Hot Monitoring parameters
WARMUEBERWACHUNG_BLK_H_L turn signal rear left
WARMUEBERWACHUNG_BLK_H_R turn signal rear right
WARMUEBERWACHUNG_BL_L brake light left
WARMUEBERWACHUNG_BL_R brake light right
WARMUEBERWACHUNG_RFS_L reverse light left
WARMUEBERWACHUNG_RFS_R reverse light right
WARMUEBERW_RL_BL_1_L tail light 1 left
WARMUEBERW_RL_BL_1_R tail light 1 right
WARMUEBERW_RL_BL_2_L tail light 2 left
WARMUEBERW_RL_BL_2_R tail light 2 right
My Ride: 530i
Running into the same problem with my back right taillight. How did you get into coding?
FEHLERMELD_CC_RL_BL_1_L tail light 1 left oe
DavaiLave
08-02-2022 02:16 AM
