Dension and Ipod Interface Fitting Info
My Ride: 2008 525d MSport
19" 172s
Leather - Heated
No-Nav, M-ASK, MP3 Playback, BMW Ipod Interface, CD-Prep
Here is some important info for people installing a Dension or BMW Ipod Interface.
If your car has the CDC Preparation option SA694 then according to the BMW Parts catalogue you do NOT need the Part 61.13.6.931.507 Diagnosis Inteface MOST, but in fact you DO need this part.
Basically the Fibre Optic loop comes from the M-ASK unit to the back of the glovebox, and this is where you open the connector to get the IN/OUT sides of the bus for installing the Dension/Ipod Interface. However, the OUT side of the bus then proceeds to a MOST Diagnotics port located in the glovebox UNDER where the torch would be plugged in to charge (don't worry - I'll add pictures). In cars without the CD Changer fitted there is a blanking connector which effectively terminates the fibre bus loop. This is where part 61.13.6.931.507 comes in - it replaces the blanking connector and allows the fibre bus to complete its loop back to the M-ASK.
I didn't have access to the above part, so instead I dismantled the connector that was already there, and re-used the connector I removed to add the Ipod Interface. I will put this all back once I get the connector from BMW.
The connector is behind a small panel located behind and under where the torch and glovebox door piston are located. Hopefully the pictures will give you a better idea where this port is located. Unfortunately most of the pictures were taken after I had bypassed the connector and completed the loop, but hopefully it should help.
I should say thanks to StonedAgain who pointed me in the right direction with this part and made me go searching for where it fitted - dealer was absolutely useless!!
Shows the blanking connector removed and disconnected.
This plugs into the blanking connector.
Some more pics (trying) to show where it's located...
This one if from below looking up
My Ride: 2006 520d - 19" 172s- Remapped - LCI taillights V6 cables - LCI xenon headlights - Denison 500 with BTA1500 - led interior lights - OEM led number plate lights
Planned mods:
Folding mirrors - Modmynav kit - High gloss shadowline trim -
19" 172s
Leather - Heated
If you do not already have the CD Changer fitted, then this connection block is likely to be a blanking connector meaning that you will need the part mentioned above.
slickrick
06-12-2015 04:10 PM
JHR-5
05-13-2015 05:28 AM
turbogate
04-11-2015 05:02 PM
