Dension 500 Install
Old Jan 9, 2010 | 10:43 AM
jamesperkins's Avatar
I have a UK spec 2009 E60 520D se with Business Nav and CDC (glovebox). The single cd/dvd player in the dashboard plays MP3 cds showing text on the screen.
I have today installed a Dension 500 following the instructions included in the box with the fibre optic cables that originally went into the CDC plugged into the Dension (car side) and a separate (2 way) fibre optic cable running from ther Dension (CDC side) to the CDC.
After updating the firmware on the Dension, I have managed to get the IPOD (and US working through the Dension. HOWEVER, I do not get any text info displayed on the head unit - just track numbers.
I have read about the subject extensively and found how some people have managed to get the IPOD showing text info on the display ok. What am I doing wrong.
I appreciate that the Dension website says that E60s with Business do not display Text BUT it looks like some people have made it work??!!
Old Jan 9, 2010 | 02:13 PM
methodsound's Avatar
My Ride: 04 545i sport, stick, L7, sat, nav. Charcoal/ runflat/ cdv delete. Suede headliner/ trunk, 3 way front speakers, four 8" subs in rear shelf, ACM, iPod dock in ash tray using gateway 500 with MP3 text and video on screen, MRTM aluminum pedals/ door pins, 10 farad cap, sound processor, line conditioner, 2 amps ( 4x100 and 2x200)
It sounds like you are in the iPod user interface menu. Try to find the "source" menu. It should look like this:
1) Gateway AUX
2) Gateway UI
3) iPod UI
4) Gateway USB
Select "Gateway UI" for text on screen ( this locks the iPod controls, but allows folder searching on the iDrive )
iPod UI unlocks the iPod controls but has no onscreen control.
Old Jan 9, 2010 | 02:29 PM
1) Gateway AUX
2) Gateway UI
3) iPod UI
4) Gateway USB
I don't see any of those options, just 6 CDs / discs. Which seem to replicate playlists maybe? Disc 6, tracks 2 and 3, can be used, holding the forward key on the steering wheel to toggle either control via ipod or control via i drive. But no sign of those menu options.
Old Jan 10, 2010 | 05:33 PM
turbogate's Avatar
Make sure you have the dip switches set correctly. I had the same issue until I changed the dip switches settings and everything worked. I don't remember exactly what the settings are, but you can find it by searching on here.
Good luck
DavaiLave
Aug 2, 2022 02:16 AM
huntyuk
Jun 27, 2015 12:19 PM
ashamlawi
May 10, 2015 09:11 PM
shervinj
Apr 23, 2015 05:42 AM
turbogate
Apr 11, 2015 05:02 PM
