dealer said not to change trans fluid with 70k.
Old Apr 21, 2009 | 10:59 AM
turboawd's Avatar
My Ride: 2006 BMW 550i
i have an 06 5550i with 70k.
should i go ahead and change the trans fluid, or leave it alone?
Old Apr 21, 2009 | 11:01 AM
turboawd's Avatar
damn, i posted in the wrong forum.
how do i delete a thread?
Old Apr 21, 2009 | 11:03 AM
RacerX's Avatar
I would vote to change it. I'm can not see any reason why new fluid is worse than the old fluid. It is probably not good for BMW if the tranny lasted a million miles.
Old Apr 21, 2009 | 11:22 AM
ShadeZeRO's Avatar
Other than the cost associated with it...I say change the fluid.
But make sure its' done by a professional. AFAIK the fluid system in BMW's are sealed air tight.
Old Apr 21, 2009 | 11:42 AM
cleung's Avatar
the dealer says don't change because bmw claims its tranny fluid is lifetime , I tend to disagree however I would definitely suggest letting the dealer do this because I have heard some horror stories of tranny errors occuring after a fluid change.
Old Apr 21, 2009 | 04:23 PM
mhs525's Avatar
We are stuck between a rock and a hard place on the tranny fluid. My dealer wouldn't change mine and neither would Turner Motorsport. I have read that it has to be done in a very specific way so if you have an independent shop do it and you have problems after BMW won't cover you.
Old Apr 21, 2009 | 05:40 PM
mag75's Avatar
I have talked to a local mechanic about this. His consensus - if the tranny fluid was changed at 30K, then it is beneficial to do it at 60K (or 70K in your situation). If the tranny fluid has never been changed, then he recommended not doing it until after 100K.
I know this doesnt seem very logicial but it is almost the "if it aint broke, dont fix it" mentality.
Old Apr 21, 2009 | 06:01 PM
lcc014's Avatar
My Ride: E60 530i
Engine: M54
Check out do-it-yourself sub forum.
Old Apr 21, 2009 | 07:53 PM
BrianTx5's Avatar
My Ride: 2005 545i | Black Sapphire Metallic | Black Dakota Leather | Anthracite Maple | 6 Speed Manual | Sport Package | Logic 7 | Sirius Satellite Radio
Model Year: 2005
Is it an automatic or manual?
It seems to be a bigger issue (to change, or not to change) with automatics.
I would change it based on what I have read.
I changed my transmission and differential fluid at 50,000 miles. I now have 75,000 miles and have had no problems.
Old Apr 22, 2009 | 02:56 AM
uheenada's Avatar
My Ride: 2005 545i SMG
I have SMG tranny and it only took indy mechanic 30min to replace both tranny and differential fluids.
I'm not sure how difficult would be in an AT but I'm assuming there's a drain hole as well?
