ok...so i have my shop instal the 8000 hid fog lights....
now,,,,the xenon ds1 bulbs(right and/or left) r NOT TURNING ON(NOT LOW BEAM ,,NOT HIGH BEAM ?@?#@?@??@#)... when i turn the light button on A( AUTO) and i press fog lights....the fog light come on.....and the angel rings...come on...but NOT THE HEAD LIGHTS... when i turn the light button 2 times right...on a low beam position....also the angel ring come on....BUT NOT THE HEAD LIGHTS..... look like every else( fog light and angel rings) work fine....BUT NOT THE HEAD LIGHTS( DS1) i chek all the fuses...and they r ok.... so i guess i fuck up the ....CONTROL UNIT XENON LIGHT...or WHAT CAN BE THE PROBLEM??? ADVICE MACH APRICIETED...ON TOP OF THAT I HAVE TO DO THE STATE INSPECTION( AND WILL NOT PASS IF THE HEAD LIGHTS DONT COME ON!!) OR I CAN NOT DRIVE NITE TIME.... please help |
so...look like i have to go to the rip(dealer)ship????
I dont think the fogs would cause the headlights not to turn on. Just to make sure, have them unplug the HID fogs and try it again.
the fogs cannot mess up the low beams at all. U have a 2006 530i. How did they install the HID fogs? Did they take out ur headlight? Something they forgot to plug? SOmething came loose? But that cant be. try disconnecting the negative and then reconnect it and see if that works
nothing happen...still no head lights......:((
please help |
bump!
If you decide to take it to the dealership, make sure to remove the fogs before doing so. Just don't want them to blame it on the fogs and put it as your fault.
my warranty end it up in august...so dose't matter....if is my fault or not....:((
i will get ready to be rip off.... so i will look like the red skin indians.... :) monday....will be the rip off day.. :(( |
