Connection for after market Audio
Hi all experienced E60 owners,
I juz got my 06 525i last week and the original Standard Car Audio is making me sick. (It sound so bad)
I got a unit of the RockFord Fosgate 360.2 + a 6 channels amp.
I thnking of getting a new set of 2ways speakers (run active) + a sub.
Before the installation there are a few questions come in mind, hopefully some kind people in this forum can help me.
1)Are the standard (8 speakers) sound system come with any amps?
2)How do I connect the RF360.2 processors? Will it effect the i-drive?
3)Can the original front door mid speaker location hold a 5" mid bass?
4)Will it void the car warrenty if I change my sound system?
Please Help..... Thank You
My Ride: E46 M3
E60 530i
wow Ifeel your pain Itoo had a 525i and i agree sounds horrible... I nw have a 530i with premium sound and logic 7 and Ihave to say it's a worls of difference the bass sounds inclredible and the highs are awesome and ofcourse the EQ in the idrive lets you adjust everything where as my 525 was only bass and treble very lame .... i'll never own a BMW withought premuim sound and logic 7..... good luck on your improvement efforts though I know its really needed in that car..
The bad sounding is for sure, but still do not has much confidence on installing after market sound system into the car.....
I wonder how to connect the RF 360.2 into the system? with speakers output or with RCA out put from idrive?
KU, If I have the standard audio (Euro version) without an amp at back and sub under the sit, do I still able to wire up my 360.2 without touching my i-drive infront?
Eclipse,
Our cars are somewhat complicated im finishing some complex wiring on a full system and let me tell you, what a headache. If anyone can help you KU, sure knows his stuff.
RJ
My Ride: 2005 530i Silver Gray/ Gray Leather. SP,PP
the place i go to by my house is very reliable they do alot of high end work.. including a couple of the miami dolphins players cars... they did my system in my audi with a kicker 700.5 wonderful amp 5 channel worked great.... when i got the 525 i went there and inquired about installing the same in that car my tech guy told me i neede some type of converter to split the sound and distribute it... it was like 299 for the part he gave me the part # and i found it on ebay for 180.00 i'll try to find out exactly what its called... if your going with a 5 channel set up you'll probably be advised to get the same.
I have the Audiocontrol lc8. which is a loc. You can also use a jl cleansweep, to flattened the speaker outputs, but the 360.2 will do that and more.
you should also look into the Alpine PXE-H650 thats coming out next week and the JBL MS-8 that coming out in the fall.
