Confused newbie. Hi all!
My Ride: 08 535i Blk on Blk, Sport package, Premium package, 166 w/ Michelin PS2's
Proud new owner of 08 535i w/ sport suspension and 124's wanting to upgrade to 166's with Michelin PS2's.
The confusion comes from all the posts i've read (yes I did a search) about M5 tire sizes 255's front and 285's rear rubing but i've read some have 166 with spacers.
So to get it clear if I get 166's with 255's and 285's with no spacers I will rub on the rear fenderwell.
If above is true, then wouldn't 275's in the rear with a 10mm spacer rub also???
Also could someone that has the rub tell me when it happens? ie bumps, hard acceleration, hard braking, etc.
Thanks
Thanks
welcome aboard , YOU'RE GONNA LOVE THE TWIN TURBOS.
PLEASE POST PICS OF YOUR CAR, SPECS and YOUR LOCATION.
Wait a while and You will see our expert in Numbers, THE DOC AKA Drlev99, who will answer your questions easily.
yes, the 255s and 285s will rub on non-M5. As for the spacers and numbers, ill let THE DOC handle that, its his specialty
My Ride: Bmw 530d 2004
My Ride: 545i Sport
Engine: N62
Thanks
Thanks
P285/30R19 Vs P285/35R19
The 30 indicates that this tire size's sidewall height (from rim to tread) is 30% of its section width(285). The measurement is the tire's section height, and also referred to as the tire's series, profile or aspect ratio. The higher the number, the taller the sidewall; the lower the number, the lower the sidewall. We know that this tire size's section width is 285mm and that its section height is 30% of 285mm.
Example: 285/35R19 (M5 wheel)
285mm x .30=99.75mm
99.75mm x 2=199.5mm
199.5mm + 482.6mm(19")= 682.1mm or 26.85"
Example: 285/30R19 (Non-M5 wheel)
285mm x .30=85.5mm
85.5mm x 2=171mm
171mm + 482.6mm(19")= 653.6mm or 25.7" a difference of 1.15 Inches. Between 275/30 and 285/30 Non-M5 wheels, there's only a 0.64" difference.
1.15 inches may not rub on stock rear suspension but most here has dropped their whips. Hope this helps. G/L
My Ride: 545i Sport
Engine: N62
And for the front: M5 Vs Non-M5
Example: 255/40R19 (M5 wheel)
255mm x .40=102mm
102mm x 2=204mm
204mm + 482.6mm(19")= 686.6mm or 27.03"
Example: 245/35R19 (Non-M5 wheel)
245mm x .35=85.75mm
85.75mm x 2=171.5mm
171.5mm + 482.6mm(19")= 654.1mm or 25.75", a difference of 1.27 Inches.
255mm x .40=102mm
102mm x 2=204mm
245mm x .35=85.75mm
85.75mm x 2=171.5mm
to the forum, member rizbel has provdied some great info already. nothing to add there except possibly getting 166 wheels with the M6 offsets,no spacers will be needed with that offset. The M6 rear offset is ET 17, M5 rear offset being ET 28. The 11 mm difference will give you a wider stance, most members with M5 offsets add spacers later to get the wider stance the M6 offset will give you stock. GL with your purchase decision...
Originally Posted by Bteljuice' post='633784' date='Jul 27 2008, 06:06 PM
WOOOOW, SO NOW WE ARE PROUD TO ANNOUNCE WE HAVE A NEW EXPERT WITH NUMBERS ON THIS FORUM
way to go Rizbel
way to go Rizbel
I totally missed the height difference between the 40 and 35 series. That was the key and thank you very very much.
So I think the best for what I want will be the 166 w/ m6 offset with 255/35/19(26") front and 285/30/19(25.8") rear and I should be rub free. Correct?
Now where is Garry's email and do we have a hook up at Tirerack??
You guys rock!!!!!
Opps forgot to answer someone's question. It is the twin turbo. Will post pics after the tint and then as the mods continue. Got bit by the mod bug with my Z06, but I sold it
Now have new toy. Let the mods begin!!!!
Thanks to all!!
Thanks to all!!
Looking back I see my numbers vary from Rizbels. I think because he did the math and I just used the specs from Tirerack. Just wanted to make sure I was choosing a size that is available.
