Cic controller help
Hi I've a quick question I've found a cic controller online but it says
It's for e70/71 . I'm wondering will it do my car an 06 e60 ? I know it'll have to be coded for the extra functions but will it do , thanks in advance
I think the part no. Is 9235245
Yes it will, I have the same one in mine.
Programming took about 30 minutes and I remember Speediguns telling me his took about 5 minutes and he thought something didn't take. So there appears to be difference in the time it actually takes. Are you planning to order a new console cover trim, or will you modify yours? If you modify, I would strongly suggest that you find an old trim or a way to do a practice cut and make a good template. The contour of the cut is quite tricky and is not very forgiving.
I can confirm it works on pre lci ccc I have a 2004 03 build and yes shortcuts still work I do remember reading however that you need to have your car updated to at least some software where you get the grey menus on the screen I never knew they even had anything before that but apparently they did. also I've read some people have done this mod and the dealer has refused or failed to code it for them. it would be good if you learned how to code yourself or know some one who can code it for you. so its one of those things I think you just gotta try and if it doesn't work go back to using the old controller and sell your new one on eBay
thx spediegunz, will find the controller first. but is the part number for the controller the right one, because i have a europe car
or do i need a different cic controller part number for european cars.
ericsbro good luck with the controller project, does your new controller also have the light in it.
thx tony, i found a cic controller with the part number 65829205177
will this one also work.
or can i only use the controller with the part number (9235245) that you and ericsbro are using.
have been looking around but didnt have any luck finding the controller with that part number.
