Changing VCGs, what else should I change?
First post...I am installing new valve cover gaskets in my 05 545i, prod date 02/05. I've read through many posts on this forum and ordered many extra parts to change out, in addition to the vcg's. From the forum, I compiled a list of other parts to change. I'm curious if I missed anything, as far as parts or special tools? Here is what I ordered:
valve cover gaskets kit (with screws, misc other gaskets)
spark plug tubes
vanos solenoid o-rings
exhaust camshaft pos. sensor/o-rings
valvetronic motor gaskets
upper timing cover gaskets
timing chain tensioners
alternator bracket gasket
waterpump
radiator drain cock/plug
I will be tackling these jobs in my garage, over a 2 to 3 day time period.
History of the car: purchased in June 2016. I've installed a new battery (registered by indy), alternator, active steering control unit (registered by dealer, vehicle inspected as well), transmission pan/filter/mech sleeve, rectangle adapter gasket in transmission, e-box fan, disa valve-the part at the back of the intake, thermostat, moved mpm and the other module out of the spare tire well.
The only issues with the car this month, oil all over 4 spark plugs and boots, CCC just failed (would reboot and work half the time for the last few weeks, screen is now completely blank/fan runs nonstop on the back of the CCC, SOS light on dash)
The vehicle has 158,000 miles and I plan on driving it for several more years. (I do 12,000 to 14,000 miles a year.)
I love working on BMWs, it is my therapy.
Previous bimmers: 1994 318is, 2001 330i, 2004 Z4 2.5.
Current projects: 2005 545i, 1973 Porsche 911T
Thanks for any help!
Go Sox!
spark plug tubes
waterpump
Go Sox!
My Ride: '03 745Li 130,000 miles
How is this project going?
spark plug tubes
waterpump
Go Sox!
spark plug tubes
waterpump
Go Sox!
Please let us know what's happening with your ride.
Thanks, Dave
I have the passenger-side cover off ( I have an '03 745Li) and all seals replaced. I can't get the cover back on. The spark plug tubes are aligned with VC and are halfway in and I had all the bolt engaged. As I tightened the bolts, I heard a loud snap. I took the cover back off and found that I had crushed one of the three positioning clips that are under the cover. They appear to simply hold the cover in place, so I will make sure the cover is lined-up better (for the clips) and try again. I used a shop & Vac with a large straw taped into it to clean out the plastic pieces. I used this trick for the pieces of the grommets that broke off and fell in during removal as well. ( I found out that by gently grabbing the grommets with vice grips during VC removal, they don't break - then remove the grommets from the VC it's out of the engine).
Thanks, Dave
Thanks, Dave
I did end up breaking a valve cover bolt off, "luckily" it was in the timing cover. So off came the VC, again, and the vacuum pump, and then I was able to get a dremel in there at the correct angle to cut a slot in the exposed bolt, then back it out with a flat head screwdriver.
I didn't have trouble getting either of the VC's off and out. I did remove the fuel rails and also the air vent plastic shield at the back of the engine bay.
Unfastening the positive battery cable gave more leeway on the left side, as well as bending the oil dipstick tube out of the way.
I used my flexible magnetic pickup tool A LOT. I dropped many bolts and nuts into the bottom plastic tray attached to the bottom of the car. I had to remove it while reassembling the wiring and hoses as one nut was lost. I should have stuffed shop rags into the spaces below the places I was working.
So, the car started, no error codes, just reset actuve steering and I am back in business.
Thanks for responding. Best, Will
