Ceramic verses Ceramic
Old 07-14-2017, 05:40 AM
scottalexander's Avatar
My Ride: 528i
Model Year: 2010 528i e60
Engine: N52k
Default Ceramic verses Ceramic
I see there are ceramic brakes pads for sale that have a warranty of one year and other ceramic pads that have a warranty of 2 years.
They are both made out of the same material !
Can you really determine the difference between one ceramic pad and another ceramic pad?
Old 07-14-2017, 06:30 AM
NoQuarter's Avatar
Engine: N54
What are you expecting out of a brake pad warranty? That they will last X number of miles or something?
Old 07-14-2017, 06:58 AM
My Ride: 528i
Engine: N52k
I see there are Pelican Parts front ceramic brakes pads for $32 and there are front ceramic brake pads for $132.
No one at the store could tell me if there was a difference in quality.
Does the $32 pad last 10,000 miles and the $132 pad last 50,000 miles?
For $32 I could change the pad every 2 years and still be ahead.
Does Pelican Parts qualify all their vendors and parts? If so, doesn't it make sense to go with $32 pads?
Old 07-14-2017, 07:00 AM
NoQuarter's Avatar
Engine: N54
Check out FCPeuro
When the pads are used up, send them in and they will replace them
Old 07-14-2017, 08:21 AM
FormerE30Owner's Avatar
My Ride: 2005 545i, premium package, 6sp manual, cold package, navigation package.
Model Year: 2005
Engine: N62
Probably the same difference as non-ceramic pads. Just as there are differences among metallic and semi-metallic pads, there are differences in ceramic pads. Type of ceramic, binding materials etc. and price, of course. BTW, unless you are racing, tracking etc., there really isn't any advantage in using ceramics, even disadvantages in normal everyday use.
Old 07-14-2017, 09:27 AM
Vendor
PelicanParts.com's Avatar
My Ride: BMW 700 and More!
Hello Scott - What's your vehicle info and what pads are you looking at exactly?
Old 07-19-2017, 11:59 AM
BostonJon's Avatar
My Ride: BMW 530xiT (E61)
not entirely true. ceramic pads tend to produce less dust than semi-metallic pads. they do have less initial bite, however.
Old 07-19-2017, 12:17 PM
My Ride: 528i
Engine: N52k
I have a 2010 528i e60 with 2 wheel drive.
The brake products I'm looking at are the following:
Front $46 Part #: D-8918-SC-INT
Brake Pad Set D8918SC - Meyle Ceramic - D-8918-SC | Pelican Parts
rear pads:
call and ask them for Meyle pads list the front’s but for the rear that are about $40
retaining clip front $14.75: Part #: 34-11-6-757-253-M4
Retaining Clip 34116757253 - Ate - BMW - 34-11-6-757-253 | Pelican Parts
retaining clip rear $ 9.50 Part #: 34-21-6-758-059-M4
Brake Pad Retaining Clip 34216758059 - Ate - BMW - 34-21-6-758-059 | Pelican Parts
sensor front: $14.50 Part #: 34-35-6-789-492-M584
Brake Pad Sensor 34356789492 - BOWA - BMW - 34-35-6-789-492 | Pelican Parts
sensor rear: $13.50 Part #: 34-35-6-789-493-M584
Brake Pad Sensor 34356789493 - BOWA - BMW - 34-35-6-789-493 | Pelican Parts
Old 07-19-2017, 01:27 PM
BostonJon's Avatar
rear pads:
i've never used meyle break pads but have had good experience with other parts from them.
the akebono euro pads seem to be popular choice for the E60/E61 along with zimmerman rotors.
glad to see you are planning to get the sensor and anti-rattle clips as well. the process for replacing pads on these cars is very straightforward. sometimes the sensor can be tough to remove.
Old 07-19-2017, 08:32 PM
Model Year: 2005
Engine: N62
I don't consider "less dust" as a performance advantage, but maybe a "cosmetic" advantage.
