CDV - honest opnions needed
My Ride: 530i 6 speed
Now I searched for this here, but I want some recent opinions.
To those of you who have replaced/removed your CDV, what is the real difference? Is it worth it?
My Ride: 2010 750Li M sport
I look forward to recent responses too. I asked my service rep this week if it would void the warranty and he did not know...nor did he know what the clutch delay valve was.
Will if void the warranty if removed?
My Ride: 2010 550i M Sport Package - Alpine White/Blk Nasca Leather, Premium hi-fi system, Sat Radio, Nav, Cold Weather Package, Value Package, Shift Paddles, Comfort Access keyless entry, Power rear Sunshade, Front Ventilated seats, Split fold-down rear seats, Heated rear seats, Automatic high beams
I ordered the part but never put it in. It's not really DIY job on the E60, to many thing to remove (need a lift) I heard from lots of people that it's worth it.
My Ride: 2006 530i - Sport - 6spd - Orient Blue with Auburn/Anthracite
In terms of being a DIY job - I was with the mechanic as he did the work (I have no practical place to do this kind of stuff myself or I would have DIY'd it). To do it comfortably, you should have a lift or 4 jackstands or ramps to get some additonal clearance under the car. You have to remove the under-body panels, which involves maybe 5 - 10 minutes of unscrewing and unbolting. changing the valve itself is probably 30 minutes, followed by another 30 minutes to bleed the clutch system if you lost any fluid during the operation (you probaby will). Put the panels back in place and you're ready to go. An hour and a half's task if you are handy with tools and cars in general.
My Ride: 2004 545i - 6 speed manual (July 04 build), silver-grey/black, sports package std equipment (18", active roll, active steering, adaptive headlights), premium sound, bluetooth enabled, folding rear seat, lumbar, 3m hood/bumper protective film, rear tint, euro reflectors.
Originally Posted by jmdhuse' post='309039' date='Jul 10 2006, 01:28 PM
I had this done a couple of months ago... The change is not dramatic, but it is noticable. You get finer control over clutch engagement, so it is easier to shift smoothly and quickly, especially in the 1->2 shift. In my opinion, it does not make a huge change to the character of the car, but it absolutely does improve the drivability.
I had it done because my car was new and did not want to deal with bleeding the system. The BMW mechanic I had do the job clamped the hydraulic line so he did not have to bleed the system. It is about a 30 minute job.
My Ride: 2013 M5 - Sakhir Orange / Black Leather.
Originally Posted by AlexFW' post='582450' date='May 17 2008, 06:12 AM
What about the SMG ?
Basically it is a manual...
So now the question is :
+1
Originally Posted by pa550' post='583058' date='May 18 2008, 12:03 PM
Does the SMG have a slave valve that controls the clutch?
+1
Good analysis above. I would add on more item. Stock BMW shifters suck. I would def replace with an aftermarket SSK which makes the CDV replacement a great companion project.
good luck
al
+1
+1
Alex,
The SMG cars control driveline shock with computer controlled clutch hydraulics. There is no CDV on the car, thus no benefit to installing one of our modified parts.
Sincerely,
David Zeckhausen
President, Zeckhausen Racing
socale39
09-05-2023 08:30 AM
