CCC to CIC Retrofit parts
My Ride: 2008 535xi Stock
Hello Everyone,
I have E60 535xi(with the Sport Package) with CCC, I found an wrecked E60 with CIC. My question is do I simply remove the screen, the CIC unit containing the hard drive, and the climate control panel, and the Comm Box?
Then just recode them to my car.
My Ride: E60 525DA
Engine: 525 M57 straight six @225BHP
Hi Jake, you need:
- CIC Unit
- Screen
- Cable between cic unit and screen
- climate control with front panel
- combox
- usb cable
- CIC Unit
- Screen
- combox
- usb cable
My Ride: E60 525DA
From what I know is not the same, you have the usb from the mulf 2 high....am I right? The CIC used it's own USB port (2 usb ports). Hope this helps!
Hi
sorry to hijack the thread. I have all the items from above, minus USB port and cable. I also have the CAN filter, lci climate controls and panel. The cic unit is preloaded with maps and ‘free coded’. Is this all I need to make it work?
also, currently I have a ccc unit with BT option, how do I connect the BT module to the cic unit?
and as a last issue: is it possible to get RTTI information on the cic navigation at all?
thanks a lot
thanks a lot
My Ride: 2006 530xi (One black & one grey) 2010 X5 35d 1974 BMW 3.0CS 2008 535i, 2009 335d, 2011 X5 35d, 2008 335i FBO
also just got a F10 535xi with a pretty nice system. Since the car is going to be parted out, I will be pulling out that system as well.
BMWE60geek
Aug 17, 2021 06:58 AM
rustyj
Sep 24, 2012 04:40 PM
