I need the left, right, and center supports. Along with Battery cover. Extra Pushpins would be nice.
here is the link to the PDF writeup, but there are No P/N's: https://5series.net/forums/index.php?act=at...st&id=39326 |
perfect... correct me if I'm wrong, but I only need the 3 supports, the battery cover and a few small push pins, right?
there is No Part number on there for the battery cover. I'm pretty sure I need this to. |
I'm swapping to an OEM rear m-tech Can't help you there but I would look closely at the part numbers between the stock and the m-tech to see what can be reused. |
