Can someone explain the harm of going with a lower offset?
My Ride: 2005 530i - Alpine white with auburn interior; tip, xenon, pdc, sirius, prem, cold weather, red reflectors and xpel.
I have a 2008 535xi with Style 123 rims from a 2005 530i Sport. While I have been given conflicting information about the offset, they probably are 20 and not 43. I believe this pushes out the rims further. My dealer says the fitment is fine, albeit I am not sure how knowledgeable they are on rims. The handling is definitely nicer than the standard 17" wheels and I haven't had any issues that I noticed. Is there a safety or wear issue from this setup?
My Ride: 2007 E63 AMG | Obsidian Black | Schwarzes Nappa | Black BirdEye Maple | Premium II Package | Electronic Trunk Closer | Parktronic
Engine: RPi/Powerchips custom ECU tune, RPi Ram Air Kit (BMC filter, scoops), RennTech Sport exhaust, secondary cats, charcoal and resonator delete, custom AAA x-pipe
Exterior: 50% side windows / 35% rear window Formula One Pinnacle Series | Flat AMG hood emblem
Suspension: Renntech Lowering Module
Wheels/Tires: Radenergie R10, Falken FK452 245/30/20, Yokohama ADVAN Sport 285/25/20
2005 545i Sport SMG | Ti Grau | Schwarzes Dakota | Anthracite Maple | Logic 7 | Nav
Engine: Custom AFE CAI, Superchips ECU remap, Sprint Booster, RDSport Dual Exhaust Conversion with Quad Pipes and X-pipe, 3 resonators deleted, 90mm tips!
Exterior: M-Tech Aero kit | M5 Mirrors | M5 Rear Bumper | Trunk Lid Finisher | Vorsteiner decklid spoiler | 50% Formula One Pinnacle Tint
Suspension and Brakes: Bilstein PSS9 coilovers, JBT BBK: 16" cross-drilled rotors, 8 piston and 15" cross-drilled rotors, 4 piston
Wheels: VIP Modular VR 02 20x9F, 20x10R | Toyo T1R 245/30/20F, 285/25/20R
Lights: PIAA 4150K Xtreme White Plus fog lights, AIB v3
MOST IMPORTANT: Hardwired V1; =)
ED Date: 4/7/05, Re-delivery date: 5/21/05
Your dealer is wrong. The fitment is not fine. Have you already mounted these wheels onto your 535xi?
I will leave that up to our resident AWD expert cmansbimmer. Also, forgot to mention that our admin das knows quite a bit as well.
Originally Posted by NY550i' post='461831' date='Aug 23 2007, 05:29 PM
What size tire? 245/40/18? They are not rubbing?
My Ride: 2004 545i - 6 speed manual (July 04 build), silver-grey/black, sports package std equipment (18", active roll, active steering, adaptive headlights), premium sound, bluetooth enabled, folding rear seat, lumbar, 3m hood/bumper protective film, rear tint, euro reflectors.
Originally Posted by macct' post='461838' date='Aug 23 2007, 02:41 PM
No (with 245/40/18 set-up). I believe it makes the wheels & tires stick out more than normal. If I put the right inputs in on 1010 tires calculator (saw from another thread), the rims are 17mm further away from the strut housing & extend 29mm more on the outside edge over the standard 17" wheels.
I guess if the wheel is significantly changed from the original setup you could see higher bearing wear over time, but it might not be anything you notice.
My Ride: Fully Loaded Monaco Blue 550i Sport
Post a picture... im surprised you are not rubbing but your car definitely should look like a go kart.
timmay77
09-24-2015 09:38 AM
umnitza
09-02-2015 11:28 AM
