Can a resistor burn out a headlight?
Old 09-29-2009, 07:32 AM
ShadeZeRO's Avatar
Originally Posted by Brit_in_NJ' post='1020180' date='Sep 29 2009, 11:23 AM
No. Did a fuse blow? Listen to Mike...he has an LED obsession!
LEDs don't draw much current which is why you use a resistor to draw more current and fool the car's LCM to think it has a regular bulb attached. Provided you don't unstall a resistor that a) is too low in ohms (which could draw too much current) or b) too low in watts (it might get too hot and melt) you should be fine.
If you are blowing fuses you might have a short somewhere so don't put a bigger one in!
No fuses have been blown. So I don't have to worry about that.
I'll swap out the bulb, and see what happens.
Old 09-29-2009, 07:43 AM
Banned
John@Motorcepts's Avatar
My Ride: A Car
dont swap the bulb yet. Or try this:
1) Switch back to ur stock and see if it turns on. If it still doesnt turn on, it should be ur ballast.
2) Swap ur ballasts from the working unit to the bad.
3) Determine what needs to be replaced.
4) Then find Garry at Newport for BMW parts
Old 09-29-2009, 08:12 AM
ShadeZeRO's Avatar
Ballast, on a headlamp?
I thought the D1S had an integrated ballast (Fixed into the headlight).
Old 09-29-2009, 08:14 AM
Banned
My Ride: A Car
THE D1S has an inetgrated ignitor on the bulb. THat huge square box built into the bulb is the ignitor. Not ballast. Tjhe ballast is underneath the headlight. The bigger one is the ballast and smaller one is control box.
Old 09-30-2009, 01:47 PM
E92-Lighting's Avatar
My Ride: Next Gen LEDS
i highly doubt the resistor has anything to do with your headlight going out
Old 11-01-2009, 05:50 PM
ShadeZeRO's Avatar
Actually, after further investigation with myself and a few other 'in the know' people i trust.
Turns out it can.
The resistors I put in are 50w 6ohm. They were drawing way to much power, and burning out the HID bulbs themselves.
I need to find some new resistors asap, as im' on my backup set of OEM bulbs right now.
Old 11-15-2009, 09:20 AM
crug75hid's Avatar
I wanted a High Intensity Discharge kit which is a very cool light and
better visibility especially during night driving. I opted to go with
the single beam HID kit too and love it, they are cheaper on ebay but
I wanted a warranty so I got it here
Sealed Beam
Headlight Kits
, or you can try one of the vendors. Also some of
the forum sponsors selling
Headlight Kits
usually have a sale going on. Either way its a
great system, and very easy to install.
Old 11-18-2009, 09:12 AM
Originally Posted by nigxdoof' post='1020162' date='Sep 29 2009, 07:05 AM
That sounds bogus. I have LEDS for every light on my car... and I mean every light! lol, haven't had a problem yet.
There's not one bulb in my car that is a regular bulb.. LOL I know I'm crazy.
+1 dealers/SA never know what they are talking about!
Vman33
03-14-2022 04:43 AM
bestofthebest
03-28-2016 02:47 PM
umnitza
11-25-2015 11:10 AM
Kewill0360
09-28-2015 07:32 AM
Bogdan7
09-23-2015 11:40 AM
Quick Reply: Can a resistor burn out a headlight?
