Can I run 19x9 with 20 offset in front and 19x10.5 with 25 offset in b
My Ride: E60
Im getting new rims this week and want to run a aggressive set up without spacers. Need some help and advice. Want to make sure that I can run this set up without any issues. 19x9 with 20 offset in front and 19x10.5 with 25 offset in back. Probably going with 245/35/19 and 285/30/19 in back or if I can 255/35/19 and 295/30/19.
Thanks for the advice,
Andrew
Andrew
My Ride: E60
Anyone? I know the offset is perfect. OEM is 20 and 22 compared to my 20 and 25. I had the same tire set up but in a smaller profile 30/25 on my 20's. All the research I've done I see most people doing 275 and 285 in rear. Anyone out there with 255/35/19 and 295/30/19 on 9 and 10.5 rims size with similar offset?!!!
Yes you can. I just put 19X9.5 +33 on the front with 18mm spacer so thats +15mm total off set with a 245/35R19 and 19X11 +25 no spacer with a 285/30R19. There is no rubbing ever and have more roome for more tire. I have heard of as big as a 305 in the back and you should be able to run a 255 in the front. https://5series.net/forums/topic/122948-new-wheels/
Virak1985
06-16-2015 01:24 AM
