Brake light upgrade
I have a 2004 E60 and was wondering could the brake lights bulbs be upgraded to put out a brighter light ? ![Confused](https://5series.net/forums/images/smilies/confused.gif)
if(typeof(cachebuster) == "undefined"){var cachebuster = Math.floor(Math.random()*10000000000)}if(typeof(dc opt) == "undefined"){var dcopt = "dcopt=ist;"} else {var dcopt = ""}if(typeof(tile) == "undefined"){var tile = 1} else {tile++}document.write('');
My Ride: BMW E60
Model Year: 2016
Dude, did you read his post?
Yes, you can upgrade the bulbs to something brighter, LEDs even.
However, what exactly is the issue here? Is your stock ones dying? The way the tails are, pre or LCI, the brake lights are definitely noticeable and bright.
Yes. My friend who has a 2004 525i tried to upgrade his brake lights to LED and his blinkers to LED but it was a hassle. You need resistors and that messed up his left tail and the right one started having strobe effects. Its much more cost efficient to upgrade to LCI tails.
My Ride: BMW E60
Model Year: 2016
A pair of resistors are about $10 or so. If he changes out all four brake bulbs, the cost is $30-$40 at most. How is that less cost efficient than spending $1000?
Sorry to say, your friend uber failed in his attempt, and should leave it to someone that know what s/he is doing. I have done this for people before (rarely, but a few times), and it has always been fine. The strobe effect is likely do to the resistor not functioning correctly, resulting in the car pulsing the current to the brake lights -- same as what happens with front turn signals when the car throws a fit about drawing the wrong current.
Additionally, the LCI brake lights are not brighter man... they use the exact same bulbs. Potentially you could argue that the overall design of the tails make the light emit more noticeably, but that's really a stretch.
Just to end this or
tl;dr: don't bother. Unless your bulbs are dying or out, leave it the hell alone.
No it's not.
Just to end this or
Just to end this or
TexaZ3
05-06-2015 09:54 AM
