BMW OEM Plate Light LED's
#93
My Ride: 2007 E60 530i
Color: Jet Black/Black Anthracite
STEP | Sport | Premium | NAV | Logic 7
EXTERIOR:
M-Tech Kit | M5 Mirrors, Trunk Finisher | Jet Black Kidney Surrounds | Madico Charcool Tint 54%, 35%
LIGHTING:
Euro-Headlights | Euro-LCI Tail Lights | AiB V3.0 | Solaris Invisi-bulbs | OEM LED Plate Lights
PERFORMANCE:
Porterfield R4-S Brake Pads | K&N Air Filter
WHEELS & SUSPENSION:
Work VS-XX 20x9, 20x10 | Toyo T1R 245/30/20, Michelin Pilot Sport A/S 295/25/20 | KW V2 Coilovers | Rogue Engineering 15mm Spacers
Siemens relay #4671168E (from local auto store in NY, at cost price is $9 each, auto stores sell them anywhere from $12-15 each)
#94
My Ride: 545i
#95
EXTERIOR:
LIGHTING:
PERFORMANCE:
Fry's Electronics has relays, but they're too big to fit through the plate light housing hole. You said you removed your trunk liner already, so that shouldn't be an issue for you... but the dimensions of the relay are something to think about.
#97
EXTERIOR:
LIGHTING:
PERFORMANCE:
The OEM LED's are basically plug-n-play, but you need a resistor/relay combo to prevent strobing on startup and a bulb out error message in I-Drive.
My friend and I are in the final stages of testing a build for an adapter cable. Price has yet to be determined, but once he figures out the cost of parts and labor I will start up a group buy.
#98
Hurry up man!!!
#100
EXTERIOR:
LIGHTING:
PERFORMANCE:
Be patient guys. My friend is waiting on some new relays to be delivered. We have to do some more testing with different amp ratings because the current set of relays I have buzz when idling. We're trying to keep the relays small in size so you don't have to remove the trunk liner when installing.
