BMW E60 M5 steeringwheel in a 530d with Steptronic
My Ride: Bmw E60 530d
hi everyone. can somebody tell me if its possible to retrofit a M5 steeeringwheel WITH paddleshift into a 530d with steptronic. and if its possible, what do i need more than the steeringwheel?
Here you go....
Retrofit SMG
I am after the same project but on a 6 series. It looks quite tricky for my car as it is a 2004 and it seems like the steptronic has changed.
Otherwise it looks like a rather straightforward install. Motivemods sells the harness from the US and you need to get yourself a proper M5 steering wheel.
Good luck. Let me know if you find any more info.
Regards
Retrofit SMG
Regards
My Ride: BMW M5 REPLICA 2006 (535 TWIN TURBO)
EVERYTHING APART FROM M5 SHIFTER WHICH WILL BE DONE SOON
Here you go....
Retrofit SMG
Regards
Retrofit SMG
Regards
Here you go....
Retrofit SMG
Regards
Retrofit SMG
Regards
My Ride: 2005 E60 545i Manual, Sport, L7
Model Year: 2005
What about non SMG . Do the M5 or mtrch steering wheels fit without modification to the 05, 545 with MT. I hate the look of that triangular wheel.
What are the options there to get read off it. And the cost?
Thanks
Thanks
Hi there...Yes you can get the M tech steering wheel to fit...The main problem for changing these steering wheels to my knowledge was to the pre 2005 cars as the slip ring and the steering wheel have to be modified as i had to do with mine..You will have to buy steering wheel with airbag and maybe a slip-ring, you shouldnt have to many problems fitting it...(expensive though ebay should get the whole lot for about £350-400 what ever that is in $'s.....And yes you need to get rid of that triangular shaped wheel its very annoying
Model Year: 2005
Thank for this info. What about a new air bag? Does it need be coded? Or the car gonna except it?
SFx550i
04-14-2015 05:00 PM
turbogate
04-11-2015 05:02 PM
BYS2
03-24-2015 03:13 AM
