BMW E60 heated seats retrofit help
My Ride: Bmw 520d m sport
Can anyone help me with wiring of heated seats please.
I have a 2007 lci 520d m sport that i want to wire up new heated seats from 2006 535d m sport.
I have connected the big yellow plug for the semi electric and all that works ok, i have alsu reused part of the seat loom from my original seats as it had cables going to headrest, everything that side seems to be working fine.
I have a module in the new seats that all seem to be wired on the sear apart from one single plug that is missing, i dont have any other plugs from the car loom to plug into it ( see pic). I have also bought and fitted the dual switches for centre console i.e DTC/HEATED SEAT and PDC/HEATED SEAT. I just plugged in the conector used for just single DTC and PDC
From what i gather the missing plug to the heater module is for power and comms, can i take a connection from the big yellow plug for everything and if do where do i connect to if not do i need to then run wires from the heater module under seat to the switches on the centre console
Any help would be much appreciated as i am trying to get this working as the better half has a degenerative back condition and heat while driving would give her some comfort
Thanks
Thanks
Engine: N54
You won't be running any wires to the switch in the center console. Those switches communicate over the car network to the seats. That's the good news. The bad news is you will need to have the car coded to recognize this new feature.
I can only assume i need to wire it somehow or no heating power😡
