Bmw e60 2008 retrofitted CIC and Logic7
Old Nov 11, 2020 | 05:49 AM
Mje60's Avatar
My Ride: E60
Default Bmw e60 2008 retrofitted CIC and Logic7
Hi,
so I have recently bought e60 2008, and few weeks later started retrofitting CIC and Logic7, previously it had CCC and regular speakers. I am familiar with programming with nsc/tool32 and so on, so decided to program everything myself. It went quite well, CIC works fine, apart from navi, music that previously was left on the hard drive was playing fine. I recently retrofitted Logic7 from 2004 e61, had to play with wiring as it differs from e60, also update the firmware of the amp, as it is 2004 amp. At this point, almost everything works fine, apart from music loading/selection from the hard drive. It kinda plays your top50 songs, but it does not show the timer, or you cannot skip or select songs. If I try opening the library it just keeps loading and never loads. It only started happening after programing CIC to recognize Logic7. Radio is working fine, cds also play as it suppose to. The only thing is that I cannot select songs from the hard drive, even if it plays them. Does anyone has any suggestions, or could share trace file for CIC, as I had to program it several times to default mode to work. Thanks in advance!
Old Nov 12, 2020 | 03:05 AM
Mje60's Avatar
My Ride: E60
Update
I have played with cic file, used one previously uploaded to this forum, and now it works fine.
addy33
DIY: Do It Yourself
25
Nov 12, 2018 10:06 AM
richie281vn
Feb 22, 2016 03:27 PM
fanarik
Dec 10, 2012 01:26 PM
Maddog-99
Nov 6, 2012 10:49 AM
brosken
DIY: Do It Yourself
43
May 3, 2012 02:51 AM
