bmw centre cap 19inch miro csl
Originally Posted by northern-monkey' post='612000' date='Jun 28 2008, 04:45 PM
Does anyone know where i can buy bmw centre caps for the csl wheels
the original 530i 04 dont fit
I do nt want to put the miros on if at all possible
help!
help!
![Unsure](https://5series.net/forums/images/smilies/imported/unsure.gif)
My Ride: 04 525i, 04 Dinan M3
I was trying to figure out what size center caps my rims are. They measure 59-60MM but I can't seem to find the caps in that size.
My Ride: Gone Waiting
Originally Posted by DrLev99' post='612098' date='Jun 28 2008, 08:44 PM
That is interesting. I always assumed it would fit.
The VMR CSL's work with the OEM cap.
Originally Posted by vishwen' post='612151' date='Jun 29 2008, 12:15 AM
My style 124 cap fits my new breyton flame sport
My Ride: 08 Porsche 911 c2s, 01 BMW 740il, 05 BMW 525i, 06 Acura TSX navi
post some pix. I am curious to see how they look on the car.
GL with the centercaps.
Originally Posted by DrLev99' post='612159' date='Jun 29 2008, 12:32 AM
Alrighty then!
But this is about CSL's...
So we will try again ! does anyone know which fit I assume a 17 inch rim and a 19 inch rim OEM have a differant centre cap fitment ?
I will call the dealership and see if there is one that does fit
My Ride: 1985 325e (sold it in 1996) // 2001 Z3 2.5 / White / Blk Lthr / 5-spd (wife's) // 04 530i / Metallic Blk / Beige Lthr / 6-spd / Logic7 / 19" 166 Michelin Pilot Sp
Originally Posted by Terraformer' post='612313' date='Jun 29 2008, 11:36 AM
The fitment is the same. I was able to use the same center caps from my original 17" OEM wheels on my new 19" Style 166s (installed just last week--and let me state that they look awesome!)
cheers for the input
Hold up on the 124's for now. Because I know your old center caps will fit those for sure.
Monkey, I am curious if the hub size of the Miro reps is your problem. They make different sized center bores, depending on offsets. Did you have to install centering rings? Quote from Modbargain's website: *BMW E60 requires a hubcentric ring, please e-mail us for more information.. The lower offsets required for RWD E60's would have given you a 74.1 centerbore instead of the OEM 72.56.
However, I also found this on ModBargain's web site re: the Miro CSL rims:
"BMW center caps are available upon request. These wheels are compatible with OEM BMW center caps, meaning you can transfer the center caps from your original BMW wheels into these new CSL wheels."
Does anyone know if the OEM 74.10 bore rims have larger (or smaller?) center caps than the 72.56 ones? This could be your issue. You said your OEM ones are too BIG, so that is a bit odd. I would have expected too small if anything.
VMR CSL's would have solved all of these issues, correct bore size and caps that fit. Oh well.
http://www.modbargains.com/product.aspx?pf...style_wheels_JY
