BMS Powerbox installed
So basically, the installation instructions were VERY straightforward. It took me well under an hour from start to finish. No error codes and everything seems perfect. BMS says it will take 2-3 days before maximum performance is realized due to the ECU "learning" the new map. So I will report back in a couple of days and let you know.
BTW, I ordered it 2 days ago and it got to my door today with normal shipping. SICK!
I have a good number of pictures for anyone interested. Mind you, my engine bay is full of sand due to yesterdays winds here in El Paso so if you talk about me I will wish you the same winds LOL.
Next Mod, installations of the Ultra Racing bars. It has been something like a year or more since I ordered them. I cant remember but I just dug them out of my garage and got all exited again. Hopefully I get them in tomorrow.
Tonymac
Tonymac
BTW, I just tested the Velocity booster with the BMS Power box. They work together even when the BMS is put on selection three. I did it over and over again.
My test
1. I switched the BMS to selection 7 (Map with no throttle map) and turned the velocity booster on. Worked like normal. I drove around running errands for a couple of hours.
2. I switched the BMS to selection 3 (Map + throttle map) to compare it to the Velocity booster. Velocity booster was switched off. The throttle map worked great.
3. With the BMS on selection 3 I switched on the Velocity booster to map three and WOW! It snapped me back like it never did before. I was skeptical so I turned off the Velocity booster and there was a significant drop in response.
4. I kept the vehicle in the exact same configuration and while on the move, I kept my foot on the gas while at around 4 on the RPM and switched the Velocity booster on... It worked like a charm.
Myth dispelled. Velocity booster works in conjunction with the BMS Powerbox on level three and 7.
Tonymac
My test
Tonymac
My Ride: BMW
It will work together, yes, but now to test how far do you press the pedal to get WOT with different settings. I guess you would need a track or closed road for that to do it safely.
If I were to section off the gas pedal into tenths, I was only pressing about 2/10 holding it steady when I turned on the VB. I have not tested much yet as I only get to try on the interstate 10 right now. Dont want to go too fast trying something out.
My test
Tonymac
My test
Tonymac
Second, I hope its not an overkill with the Velocity booster and the BMS, you should know in about 5k miles if you burn the sensors to begin with.
Goodluck
sounds like your shoulder is feeling better if your installing a few mods, with ease
Oh yes! My shoulder is doing great. The physical therapist told me that I was weeks ahead of where I should be. What can I say... I am a Ninja.
My scar looks a little like... well, let me show you
