BMS power box is a thumbs up:)
#31
My Ride: check siggg
#33
justin
#34
i really recommend you get the bms powerbox, if you want my buddy's number at ltbmw pm me.. are you in LA? the bms powerbox really makes a difference, eliminates that delay when you step on the gas pedal, plus if you have the sprint booster already that will work hand in hand with the bms, i say leave it, coz the sprint booster is for better throttle response.. i am doing the stage 3 manifold upgrade as well, but i may do that later on, for now i'm going to enjoy the bms pbx.. also do you have an exhaust hook up already? pm me if you need his info.. thanks
justin
justin
#35
justin
justin
#36
yup yup! i will work together, put it back on and your car will be a beast!! lol!
#37
My Ride: BMW
I don't know about using the SB and BMS together. Personally I wouldn't do it. I think it would confuse the crap out of the car. The SB already reduces the throttle window so that you're already at WOT when the pedal is pressed at 75%. Adding to the BMS' throttle map, you could be WOT when the pedal is %50. Of course those are extreme approximations but I hope you get what I'm trying to say.
However, the BMS does have the capability to disable the throttle map but keep the performance gains. That way, you can use the SB for the throttle map and BMS for the actual gain of the car...Theoretically.
#39
this is what i meant by working together, bms will compliment sb. thanks for explaining it better buddy, i appreciate that!
thanks balbs
thanks balbs
#40
But then the mods would be wasteful and redundant. Why would you want to keep the SB for the throttle map if the BMS does it too. It would make no sense to disable it and then mount another mod to do it???
The BMS pbx is an all in one!
