Before and after pictures With M5 rotors
My Ride: F10 M5
Model Year: 2013
Originally Posted by ivan545' post='526945' date='Feb 3 2008, 11:52 PM
IT's good , i had to modify some stuff to make it fit better.
My Ride: F10 M5
Model Year: 2013
Originally Posted by ivan545' post='526947' date='Feb 3 2008, 11:56 PM
I had to redo the air flow sensor part and the coolant sensor on the bottom by the intake tube. and also the T-hose, i didn't use the one that it comes with.
My Ride: 2007 E60 530i
Color: Jet Black/Black Anthracite
STEP | Sport | Premium | NAV | Logic 7
EXTERIOR:
M-Tech Kit | M5 Mirrors, Trunk Finisher | Jet Black Kidney Surrounds | Madico Charcool Tint 54%, 35%
LIGHTING:
Euro-Headlights | Euro-LCI Tail Lights | AiB V3.0 | Solaris Invisi-bulbs | OEM LED Plate Lights
PERFORMANCE:
Porterfield R4-S Brake Pads | K&N Air Filter
WHEELS & SUSPENSION:
Work VS-XX 20x9, 20x10 | Toyo T1R 245/30/20, Michelin Pilot Sport A/S 295/25/20 | KW V2 Coilovers | Rogue Engineering 15mm Spacers
Lookin' good Ivan! So you decided to keep the Agio's. You're missing your center caps though!
Well it would fit when you gave it to me, but i wanted it to be perfect when its on the car, cause the tube pushes against the coolant sensor and the air flow sensor I sealed it and redo that part too.
My Ride: F10 M5
Model Year: 2013
Originally Posted by ivan545' post='526953' date='Feb 3 2008, 11:59 PM
Well it would fit when you gave it to me, but i wanted it to be perfect when its on the car, cause the tube pushes against the coolant sensor and the air flow sensor the sealed it and redo that part too.
I'll see you at the Central meet.
