Audio system too powerful
Old 01-14-2010, 02:22 PM
aresh's Avatar
Question
I have a 13.5" Jl w7, 1000/1 JL amp, and a 10 farad cap. My voltage fluctuates and when bass hits hard it gets down to 8-9 volts and amp shuts off. Obviously the alternator can not keep up with the amp's need for power. What should i do, get a H.O. alternator or a BatCAP. Where can i get a HO alternator and/or what Batcap would i need?
Old 01-14-2010, 02:24 PM
acuteperformance's Avatar
My Ride: 14 550i
get a bigger cap i think that's the cheaper route?
Old 01-14-2010, 02:27 PM
bobbyt's Avatar
I have fosgate power 1000db and a ti eclipse with no cap and i dont have any probs at all.
Old 01-14-2010, 02:39 PM
aresh's Avatar
bobbyt-yea I wouldn't think a 1000w amp would cause issues but this JL 1000/1 is known for sucking up serious power, not so efficient as other class D amps
acuteperformance- I was reading up on BatCaps and it seems like that might do the trick, not sure though. Which one should i get for my system, 300,400,800?
Old 01-14-2010, 02:40 PM
My Ride: 14 550i
that i don't know. i've never had to run a cap before. 1000/1 is some serious juice!
Old 01-14-2010, 03:00 PM
chhay24's Avatar
From my experience and knowledge about car stereo
i would replace any alternators, only thing i would do though is get bigger cap if not enough then get another one.
that should fix the problem. after all thats what the caps are for
hope this helps
Old 01-14-2010, 03:11 PM
jay bimma's Avatar
are you running a good name brand cap? some of the cheaper ones claim 10 farad but never store that kind of power.
i have a 5 farad alumapro which are the best caps out. i used to run my orion 1200D monoblock at 80% throttle at 2 ohms (about 725watts) on my previous car and i never had any issues which dimming lights or voltage.
Old 01-14-2010, 03:25 PM
aresh's Avatar
i have a Stinger 10 farad cap, which i took out from my previous system and hooked it to this one in my BMW. Is alumapro a regular farad cap or is it like Batcap? Which do you think i should get. Also my lights do dim and i have logic 7
Old 01-14-2010, 04:38 PM
aresh's Avatar
i think im going to buy the alumapro 5 farad cap, where can i get it for a decent price?
Old 01-14-2010, 04:54 PM
rjcastr's Avatar
check your setup and find out how your equipment is installed, im driving 1000 watts with no problem and my Hertz Sub hits super hard
Quick Reply: Audio system too powerful
