Attempting an Orion v2 Install on Pre LCI Halogen?
My Ride: 2005 525i 6MT
Greetings everyone,
I was thinking of attempting the orion v2 install on Pre LCI Halogen headlights and was wondering if i could get some closer pictures of them installed. I am wondering how they mount the AE ring without the projector housing.
I have noticed the install count on these headlights is lacking number and cant seem to find much info on this so im coming here for more info![Whistling](https://5series.net/forums/images/smilies/imported/whistling.gif)
What do you guys use to mount the rings (glue,Backing tape?) since most adhesive projects have the potential to fall apart due to heat? or can they mount the same way the existing dim AE ring sits in there?
Also is it even possible to reseal the headlight to prevent moisture 100% ? if so what are you using?
Pics and helpful links are always appreciated
thanks!
-Bill
thanks!
-Bill
My Ride: 2007 ★ Alpine White
My Ride: BMW E60
Model Year: 2016
I think I had pictures posted of close up when I had the for sale thread for them.
Otherwise if I remember when I am on my other laptop, I will post it.
Like I said though, you should just save up for LCI halogens and upgrade from there.
Otherwise it is possible to retro projector into pre-LCI halogen and install Orions, but buying the parts alone are just half way there (if not more) to getting a set of used LCI halogens.
![Drool](https://5series.net/forums/images/smilies/imported/drool.gif)
i found the thread you posted for the install. You also mentioned using a hot glue gun for this? i'm surprised the heat from the hid's didnt melt the rings right off. i've have hids in my low beams and am thinking this will be my end result, i know they radiate some heat.
the thought of cutting them open and the install doesn't seem to bad. a Dremel with a diamond wheel will cut through that like butter, but re sealing out the moisture i think will be a problem with cold winters here when the plastic contracts from the cold temps.
what did you use to seal up the headlightS?
My Ride: BMW E60
Model Year: 2016
hahahaha, i was waiting for this answer. "just go buy lci halogens". i found a nice pair for 750 but then another 200 or so for the cable will have to wait untill the spring. going to put on new wheels and sides before i go lci.
While we're working very hard right now on a DIY video for the E92 (we just did our 4th one), it will likely have cross over information for the E60 as far as mounting the rings. We may however have to "fuzz out" the actual detailed nature of the mounting as it's a somewhat proprietary process![Frown](https://5series.net/forums/images/smilies/imported/sad.gif)
The only issues you will have is how to open your lights, because the E92 actually bakes open, while the E60 does not.
ricki_
12
02-08-2020 09:50 PM
stillak
06-15-2015 09:51 AM
550iwa
03-27-2015 06:45 AM
andymax
03-13-2015 10:51 AM
bapeforceone
03-11-2015 04:18 PM
