Anyone running spacers on the E60 with OEM M5 wheels?
Old 04-13-2009, 06:13 AM
sy1616's Avatar
I think the M5 wheels are tucked a bit in the fender too much. Anyone running 10-15mm spacers? I like the ones at AES.
Pics???
Thanks!
Old 04-13-2009, 09:14 AM
e6t.lab.rat's Avatar
you are right about it (rears) being tucked in. i should be getting mine this friday from newport and was told by some members that a 12mm offset spacer is required for the "flush" look. h & r makes them and so does rougue engineering.
i believe the m6 166 stlye are a diff offset and may not require spacers but not sure. can someone chime in regarding this...i would rather not use spacers at all if possible
thanks
Old 04-13-2009, 09:29 AM
sy1616's Avatar
thanks
Correct, the M6 wheels have a flush offset. I'm going to try a 12 and 15mm spacer for my 545i with M5 wheels. Thanks!
Old 04-13-2009, 09:37 AM
anytime bro! just curious, why didn't you order the M6 instead, for the flush setup with no spacers?
had i known this i would of definitely ordered the M6, but like i said in a previous thread when i ordered my 166 the tech told me the M5 and M6 were the same offset. that was bs. i'll have to call newport back to see if i can exchange for the m6 offset. maybe i can stop delivery in transit...
Old 04-13-2009, 11:15 AM
Terraformer's Avatar
My Ride: 1985 325e (sold it in 1996) // 2001 Z3 2.5 / White / Blk Lthr / 5-spd (wife's) // 04 530i / Metallic Blk / Beige Lthr / 6-spd / Logic7 / 19" 166 Michelin Pilot Sp
12mm is correct to make M5 offset 166s set as M6 offset 166s are.
I just ordered the 12mm H&Rs from Nerweezy at Trinity Motorsport - you might want to send a PM to inquire.
(And for the record, I was itching to get my wheels and couldn't wait - Garry at Newport said they were on back order and I said I'd take the M5s instead.)
Old 04-13-2009, 11:33 AM
sy1616's Avatar
I thought the M6 offset wheel in M5 style was a remake and I wanted OEM stuff. Am I wrong?
Old 04-13-2009, 11:39 AM
Gene's Avatar
nope M166 wheels are produced in both M5 and M6 offsets OEM
check realoem.com if you wish to confirm for yourself
Old 04-13-2009, 12:24 PM
sy1616's Avatar
Damn, which I would have known that...live and learn I suppose!
Old 04-13-2009, 12:31 PM
pdawg74's Avatar
Pics???
Thanks!
They are, so I added rogue 12 mm spacers. Check this post out for pics:
http://forums.e60.net/index.php?s=&sho...st&p=841471
Old 04-13-2009, 06:26 PM
+1 12mm spacers will do it, pushes the offset to ET16
Quick Reply: Anyone running spacers on the E60 with OEM M5 wheels?
